.NET
Active Member
awdas
Message 1 of 9 (486 Views)
How to extrude imported dxf along polyline?
486 Views, 8 Replies
10-21-2012 05:34 PM
I have region is in external dxf file,
how to extrude it along polyline?
I can't get region after using dxfin method
                    Database myDxfDb = new Database(false, true);
                    myDxfDb.DxfIn(filename, logFilename);
                    Matrix3d dxfTrf = Matrix3d.Identity;
                    _ThisDatabase.Insert(dxfTrf, myDxfDb, true);
                    _ThisDatabase.UpdateExt(true);
                    myDxfDb.Dispose();
                    acTrans.Commit();
                    ObjectId id = AcUtils.EntLast();
                    Entity _ent = (Entity)acTrans.GetObject(id, OpenMode.ForWrite);
Alfred.NESWADBA
Message 2 of 9 (485 Views)
Re: How to extrude imported dxf along polyline?
10-21-2012 05:41 PM in reply to: awdas
look to the objecttype that is the result of inserting the DXF ==> is it a region or is it a block(definition/-reference....) :smileywink:
- alfred -
Alfred NESWADBA
Active Member
awdas
Message 3 of 9 (480 Views)
10-21-2012 05:46 PM in reply to: Alfred.NESWADBA
dxf file contain only one region object
Alfred.NESWADBA
Message 4 of 9 (476 Views)
10-21-2012 05:51 PM in reply to: awdas
and now try to insert this DXF into another drawing ==> what does it get then?
- alfred -
Alfred NESWADBA
Active Member
awdas
Message 5 of 9 (473 Views)
10-21-2012 05:57 PM in reply to: Alfred.NESWADBA
Hi alfred,
yes, I can that. dxf import as block reference.
well, how can I use this block reference :smileyhappy:
Alfred.NESWADBA
Message 6 of 9 (465 Views)
10-21-2012 06:04 PM in reply to: awdas
either explode it or use the BlockTableRecord from this object to get the parts of this blockdefinition, there you also find then the region. You can then create an extrusion if this and add it to the database.
Good luck, -  alfred -
Alfred NESWADBA
Alfred.NESWADBA
Message 7 of 9 (463 Views)
10-21-2012 06:09 PM in reply to: awdas
and a sample for how to create 3D-solids from 2D-objects could be found >>>here<<< (and Kean Walmsley has a lot more interesting samples on his site)
- alfred -
Alfred NESWADBA
Active Member
awdas
Message 8 of 9 (454 Views)
10-21-2012 07:16 PM in reply to: Alfred.NESWADBA
thanks a lot for your interrest alfred,
but my problem is not extrude region. I cant get region from dxf file.
Active Member
awdas
Message 9 of 9 (439 Views)
10-21-2012 10:10 PM in reply to: awdas
I found the solution
        public Entity ImportDxfAsEntity(string FileName, Point3d InsertionPoint, double Rotation = 0)
            ObjectId blkid = ObjectId.Null;
            Entity ent = null;
            using (Database bdb = new Database(false, true))
                bdb.DxfIn(FileName, @"c:\log.txt");
                //blkid = _ThisDatabase.Insert(System.IO.Path.GetFileNameWithoutExtension(FileName), bdb, true);
                blkid = _ThisDatabase.Insert("blok", bdb, true);
                using (Transaction tr = _ThisDatabase.TransactionManager.StartTransaction())
                    BlockReference bref = new BlockReference(InsertionPoint, blkid);
                    using (BlockTableRecord btAttRec = (BlockTableRecord)bref.BlockTableRecord.GetObject(OpenMode.ForWrite))
                        foreach (ObjectId subid in btAttRec)
                            ent = (Entity)subid.GetObject(OpenMode.ForRead);
                    tr.Commit();
            return ent;
You are not logged in.
Ask the Community
