How to do this effect? after ReDo command
Hi Guys,
I use AutoCAD 2011, VB.net
I have done a form docked on the left side of drawing dynamicly display all block in the drawing. What I have done is select all block druing drawing open process and put them into listview in the form and display them.
Once I delete some of the block, they will be removed from my form as well.
Now is my question. If I send redo command(Ctrl+Z), those deleted block will be put back to drawing, I wonder how to update my form at the same time? I could get all blocks again and refresh the listview. But I think that will take sometime if I have  lots blocks in the drawing.
Any ideas?
Yaqi
Alfred.NESWADBA
Check for event "CommandEnded" or for "ObjectAdded" (I think it will be raised when you do a _REDO)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks for the hint. Do you know where is ObjectAdded?
T
Alfred.NESWADBA
It's an event in the Autodesk.AutoCAD.DatabaseServices.Database - object.
- alfred -
Alfred NESWADBA
Hi Alfred,
I just did a test. It didn't trigger objectadded when I use redo.
