• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    yaqiz
    How to do this effect? after ReDo command
    148 Views, 4 Replies
    02-13-2012 03:04 AM
    Hi Guys,
    I use AutoCAD 2011, VB.net
    I have done a form docked on the left side of drawing dynamicly display all block in the drawing. What I have done is select all block druing drawing open process and put them into listview in the form and display them.
    Once I delete some of the block, they will be removed from my form as well.
    Now is my question. If I send redo command(Ctrl+Z), those deleted block will be put back to drawing, I wonder how to update my form at the same time? I could get all blocks again and refresh the listview. But I think that will take sometime if I have  lots blocks in the drawing.
    Any ideas?
    Yaqi
    Please use plain text.
    Re: How to do this effect? after ReDo command
    02-13-2012 03:51 AM in reply to: yaqiz
    Check for event "CommandEnded" or for "ObjectAdded" (I think it will be raised when you do a _REDO)
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    yaqiz
    02-13-2012 03:56 AM in reply to: alfred.neswadba
    Thanks for the hint. Do you know where is ObjectAdded?
    T
    02-13-2012 04:24 AM in reply to: yaqiz
    It's an event in the Autodesk.AutoCAD.DatabaseServices.Database - object.
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    yaqiz
    02-28-2012 06:54 AM in reply to: alfred.neswadba
    Hi Alfred,
    I just did a test. It didn't trigger objectadded when I use redo.
