.NET
Active Member
Message 1 of 8 (519 Views)
How to disable AEC warning message
519 Views, 7 Replies
12-18-2013 02:19 PM
We are trying to run an automated process on incoming AutoCAD drawings.  However, the process stops if a drawing has AEC object references, because the warning dialog opens (and the program does not deal with it).  Is there a programmatic way to disable the AEC warning dialog for opening?  Similar to turning off the Proxy warning?  Perhaps a Registry setting?  Thanks in advance for all your help.
Message 2 of 8 (512 Views)
Re : How to disable AEC warning message
12-18-2013 02:39 PM in reply to: elliottpd11
Are you talking about the PROXYNOTICE sysvar? If so, just set it to 0.
Gilles Chanteau
Active Member
Message 3 of 8 (498 Views)
Re: How to disable AEC warning message
12-18-2013 03:53 PM in reply to: elliottpd11
No that doesn't seem to affect the AEC warning.
Distinguished Contributor
SENL1362
Message 4 of 8 (466 Views)
12-20-2013 12:14 AM in reply to: elliottpd11
http://adndevblog.typepad.com/autocad/fenton-webb/page/2/ :: Disable Task Dialogs programmatically
These ‘hide dialog’ settings are stored in your %APPDATA%\Autodesk\AutoCAD 2014\R19.1\enu\Support\Profiles\Unnamed Profile\fixedprofile.aws under the HideableDialogs section.
The messages comes from dictionaries stored in the Database(DWG). They can be removed after opening but that's too late to avoid the messages.
Unfortunately up to now i was not able to remove these AEC (proxy/zomby) object from the database before showing it in the Application. The next code failed:
aexDB.ReadDwgFile(aecPathname, FileOpenMode.OpenForReadAndWriteNoShare,true, null);
if (Regex.IsMatch(id.ObjectClass.DxfName, "Acad_Proxy_Object", RegexOptions.IgnoreCase))
//other ghost/zomby like objects
if (Regex.IsMatch(proxy.OriginalDxfName, "AEC", RegexOptions.IgnoreCase))
//AEC like objects
ADN Support Specialist
Balaji_Ram
Message 5 of 8 (417 Views)
12-22-2013 09:57 PM in reply to: elliottpd11
Anton (SENL1362) has already provided the right answer. These settings are part of the profile settings.
Just wanted to add to it.
If you need to stop those warnings even before the drawing is opened in AutoCAD, you can directly edit the .aws file by parsing it as an XML.
Add the following as a child node under the <HideableDialogs>
<HideableDialog id="AecUiBase.PreviousVersionOpen" result="8" />
This change is to be done in the FixedProfile.aws
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Active Member
Message 6 of 8 (401 Views)
12-23-2013 04:44 AM in reply to: Balaji_Ram
We are using AutoCAD 2012, and there is not a <HideableDialogs> node in the FixedProfile.aws, so I am wondering: Do I add a <HideableDialogs> section, and where in the tree does it go?
SENL1362
Message 7 of 8 (397 Views)
12-23-2013 04:53 AM in reply to: elliottpd11
%AppData%\Roaming\Autodesk\AutoCAD Map 3D 2012\R18.2\enu\Support\Profiles
<Profile> <StorageRoot> <AcApData> <HideableDialogs> <HideableDialog id="DrawingOpen.ForeignDWGFile" title="Open - Foreign DWG File" category="Drawing Open" application="" result="1001"> <Preview> <TaskDialog Source="/AcTaskDialogs;component/TaskDialogs.xaml" Id="DrawingOpen.ForeignDWGFile" xmlns="clr-namespace:Autodesk.Windows;assembly=AdWindows"> </TaskDialog> </Preview> </HideableDialog> </HideableDialogs> </AcApData> </StorageRoot> <Name>*Fixed_Profile</Name> <Description> </Description> </Profile>
Compare this AWS before and after turning the message OFF
You can turn the messages on in AutoCAD: Options>System>Hidden Messages Settings...
SENL1362
Message 8 of 8 (393 Views)
12-23-2013 04:59 AM in reply to: SENL1362
AWS after turning the AEC message OFF:
<Profile>
	<StorageRoot>
		<AcApData>
			<HideableDialogs>
					<Preview>
						</TaskDialog>
					</Preview>
				</HideableDialog>
				<HideableDialog id="AecUiBase.NewerVersionOpen" title="Open Drawing - New Versions of Objects in Drawing" category="Version Conflict Warning" application="AutoCAD Map 3D 2012" result="8">
					<Preview>
						C:\Users\avb\AppData\Local\Temp\AecUiBase.NewerVersionOpen.xaml
					</Preview>
				</HideableDialog>
			</HideableDialogs>
		</AcApData>
	</StorageRoot>
	<Name>
		*Fixed_Profile
	</Name>
	<Description></Description>
</Profile>
You are not logged in.
Ask the Community
