.NET
Valued Contributor
HelloWorlddd
Message 1 of 5 (179 Views)
How to determine a point on one line
179 Views, 4 Replies
03-29-2014 09:47 AM
For example:
pt(0,0,0) is on the line((1,-1,0),(-1,1,0)
then I will get true
pt(1,2,3) is not on the line((1,-1,0),(-1,1,0)
then I will get false
Is there exist some method that I can use?
An example will be better. Very Thanks
_gile
Message 2 of 5 (166 Views)
Re : How to determine a point on one line
03-29-2014 11:10 AM in reply to: HelloWorlddd
You can try this overloaded Isinside method;.
        private bool IsInside(Line line, Point3d point)
            return IsInside(line.StartPoint, line.EndPoint, point);
        private bool IsInside(LineSegment3d line, Point3d point)
        private bool IsInside(Point3d start, Point3d end, Point3d point)
            Vector3d v1 = start.GetVectorTo(point);
            if (v1.IsEqualTo(new Vector3d()))
                return true;
            Vector3d v2 = start.GetVectorTo(end);
            return
                v1.IsCodirectionalTo(v2) &&
                0.0 <= v1.Length &&
                v1.Length <= v2.Length;
Gilles Chanteau
Valued Contributor
cdinten
Message 3 of 5 (118 Views)
Re: How to determine a point on one line
03-30-2014 08:09 PM in reply to: HelloWorlddd
one way is using Curve3d.IsOn() method, it has 6 overload version, you can choose one, this is the general approach
when it comes to Line, another way is using Point3d.GetDistanceTo()
a Line has StartPoint and EndPoint,abbr sp & ep.
if you want to check Point3d p, then:
d1=p.GetDistanceTo(sp);
d2=p.GetDistanceTo(ep);
length=theLine.Length;
if
A:d1+d2==length
or
B:|d1-d2|=length
thus we assume p is on the line,case A means p is on the line, case B means p on the extend, see image below:
Valued Contributor
HelloWorlddd
Message 4 of 5 (103 Views)
03-31-2014 04:21 AM in reply to: cdinten
Thank you very much, it's a easy way.
Valued Contributor
cdinten
Message 5 of 5 (100 Views)
03-31-2014 04:24 AM in reply to: HelloWorlddd
it should be. it is both easy to understand in mathematics and to convert this idea to code.
You are not logged in.
Ask the Community
