How to count entyties with .NET
How to count Entyties in MODELSPACE with .NET ?
_
Public Sub GetInfos()
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim Trans As Transaction = db.TransactionManager.StartTransaction()
Dim Bt As BlockTable = CType(Trans.GetObject(db.BlockTableId,
OpenMode.ForRead), BlockTable)
Dim Btr As BlockTableRecord = CType(Trans.GetObject(Bt(Btr.ModelSpace),
OpenMode.ForRead), BlockTableRecord)
Trans.Dispose()
End Sub
Is there any reason you can't just use the SelectAll ActiveX method and
query the count?
http://www.acadx.com
Here it is in C#:
int count = 0;
foreach( ObjectId id in SomeBlockTableRecord )
++ count;
That's essentially what AutoCAD does to get it,
and there is no simple way to do it.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Genoud Alain" wrote in message news:4897264@discussion.autodesk.com...
_
Trans.Dispose()
End Sub
"Genoud Alain" a écrit dans le message de
Danks !
