How to convert a .DWG file into .DXF file.
Good afternoon All,
How to convert a .dwg file into .dxf file.
or
How to save as a .dwg file into new .dxf file.
_gile
Look at the Database.DxfOut() method.
Gilles Chanteau
GileCAD
GitHub
Hi gile,
Thanks for reply,
i tried this but it is not converting to DXf see below code
Database.DxfOut(path, 1, true);
_gile
Database is a class.
I was meaning the DxfOut() method of the Database class.
You have to create an instance of the the Database class of the Document you want to convert to DXF and call the DxfOut() method for this instance.
Assuming you want to convert the active document:
{code}Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
db.DxfOut(path, 1, true);{code}
Gilles Chanteau
GileCAD
GitHub
Hello
Don't forget to put the DxfOut() call inside a transaction otherwise some strange behavior will occur. Also, you might consider using a higher value for precision (second argument).
PK
{code}
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Using (tr)
db.DxfOut(FileName, 10, True)
End Using
{code} Edited by: kviler on Feb 8, 2010 1:21 PM
hi kviler,
i forgot to say thanks a lot it working fine.
sorry to delay
thanks again
Have a nice day.
