Database is a class.
I was meaning the DxfOut() method of the Database class.
You have to create an instance of the the Database class of the Document you want to convert to DXF and call the DxfOut() method for this instance.
Assuming you want to convert the active document:
{code}Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
db.DxfOut(path, 1, true);{code}
