.NET
How to convert .NET ObjectId to COM int ObjectID?
8 REPLIES 8
Message 1 of 9
wesbird
990 Views, 8 Replies
I am working (actually learning) .Net in 2006. I need work with CAO which still COM based. so I use Interop to create a general function. When I work with LinkTemplate.CreateLink, it required ObjectID as int, in .Net, OjbectId as a kind of Object and I did not find any Method/properties to convert it int (Long actually).
Did anyone have the same problem before? How do you handle it? It will great if you can some example.
Thank you a lot and appreciate your help
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
8 REPLIES 8
Message 2 of 9
in reply to: wesbird
See the ObjectId.OldId property.
Dan
wrote in message news:4972035@discussion.autodesk.com...
Wes
Message 3 of 9
wesbird
Thank you,
Message 4 of 9
See ObjectId.OldId property
Albert
Wes
Message 5 of 9
wesbird
Now I have the reverse problem, how to convert COM int ObjectID to .NET object ObjectId?
Thank you,
Wes
Message 6 of 9
Do you use the Object Browser? If so, you'd see a public constructor for
ObjectId which takes an "int oldId" parameter.
Dan
wrote in message news:4974621@discussion.autodesk.com...
object ObjectId?
Thank you,
Wes
Message 7 of 9
smcclure
Does this constructor exist in 2005? I do not see it...
Is there a better way to convert an AcadBlockReference to a BlockReference?
Message 8 of 9
In AutoCAD 2005 ObjectId.OldId property can be get and put.
In AutoCAD 2006+ this property is read-only but there is constructor ObjectIId(int). You can check version of AutoCAD and use appropriate method for converting.
Message 9 of 9
smcclure
Thanks!
- Scott
”Boost
