Sometimes, I need to output some warning message to users, there will be several messages, if I use the message box, it's unfriendly, so ,I want output all warning message in the command prompt, but it's not marked.,but I don't know how to set the color.
For example, the message show in the command prompt will be like below:
Warning:
xxxx xxx xxx xxx .............
What's the usual way of output the error, warning or exception, Any help much appreciated.
Thanks for your help. Maybe I should try some others ways to output warning.
