.NET
How to connect to ObjectDBX in VB.net
6 REPLIES 6
xuyong_shy
1770 Views, 6 Replies
In vba,the follow code is right,and i can connect to ObjectDBX
CODE:
Dim objDBX As AxDbDocument
set objDBX=CreateObject("ObjectDBX.AxDbDocument.16")
in VB6.0,the follow code is right,and i can connect bo ObjectDBX,too
CODE:
dim objDbx As AxDbDocument
Set objDbx = GetInterfaceObject("ObjectDBX.AxDbDocument.16")
but in VB.net,I can't connect to ObjectDBX,the next codes don't work and get unexcepted err.
CODE:
Imports Autodesk.AutoCAD.Interop.Common
and in VB.net the function(getinterfaceobject) doesn't exit,
so please tell me how can i connet to objectDBX.
Thank you for your help!
6 REPLIES 6
xuyong_shy
in reply to: xuyong_shy
I came here with full hope,but nobody give me reply,Please help me.
Have you tried looking for it yourself. You can search the ng for
"objectdbx" and you will find some code.
Ed
smcclure
To get the AcadApplication object, call Application.AcadApplication. To get a document, call Document.AcadDocument. To define a new (and empty) variable to store the document, write Dim acadDoc as AcadDocument.
Note that you cannot create a document out of thin air. Try using Application.AcadDocument.Documents.Open if you wish to open a document in MDI mode.
- Scott
If your VB.NET code is not loaded into AutoCAD, you must
use ActiveX to access ObjectDBX using the GetInterfaceObject
method of the AcadApplication object.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5217758@discussion.autodesk.com...
Try the code:
Public Class Form1
Inherits System.Windows.Forms.Form
#Region " Windows Form Designer generated code "
Public Sub New()
MyBase.New()
'This call is required by the Windows Form Designer.
InitializeComponent()
'Add any initialization after the InitializeComponent() call
End Sub
'Form overrides dispose to clean up the component list.
Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)
If disposing Then
If Not (components Is Nothing) Then
components.Dispose()
MyBase.Dispose(disposing)
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
Friend WithEvents Button1 As System.Windows.Forms.Button
Private Sub InitializeComponent()
Me.Button1 = New System.Windows.Forms.Button()
Me.SuspendLayout()
'Button1
Me.Button1.Location = New System.Drawing.Point(104, 104)
Me.Button1.Name = "Button1"
Me.Button1.TabIndex = 0
Me.Button1.Text = "Button1"
'Form1
Me.AutoScaleBaseSize = New System.Drawing.Size(5, 13)
Me.ClientSize = New System.Drawing.Size(292, 273)
Me.Controls.AddRange(New System.Windows.Forms.Control() {Me.Button1})
Me.Name = "Form1"
Me.Text = "Form1"
Me.ResumeLayout(False)
End Sub
#End Region
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
AcadAccess()
End Sub
Public Sub AcadAccess()
On Error Resume Next
Dim AcadApp As AcadApplication
Dim ActDoc As AcadDocument
' Check for working AutoCAD
AcadApp = GetObject(, "AutoCAD.Application.16.2")
If Err.Number <> 0 Then
Err.Clear()
AcadApp = CreateObject("AutoCAD.Application.16.2")
'Visibility
AcadApp.Visible = True
' Active Drawing
ActDoc = AcadApp.ActiveDocument
Dim lineObj As AcadLine
' Points
Dim StartPoint(2) As Double
Dim EndPoint(2) As Double
StartPoint(0) = 1.0#
StartPoint(1) = 1.0#
StartPoint(2) = 0.0#
EndPoint(0) = 250.0#
EndPoint(1) = 250.0#
EndPoint(2) = 50.0#
' Line
lineObj = ActDoc.ModelSpace.AddLine(StartPoint, EndPoint)
End Sub
End Class
' http://poleshchuk.spb.ru/cad/eng
Nikolay Poleshchuk
http://poleshchuk.spb.ru/cad/eng.html
And similar code with AxDbDocument:
Public Class Form1
Public Sub New()
MyBase.New()
End Sub
If disposing Then
End Sub
_
Me.SuspendLayout()
'Button1
Me.Button1.Location = New System.Drawing.Point(112, 112)
'Form1
Me.Name = "Form1"
Me.Text = "Form1"
End Sub
#End Region
Private Sub Button1_Click(ByVal sender As System.Object, _
UseObjectDBX()
End Sub
Private Sub UseObjectDBX()
Dim dbxDoc As AxDbDocument
' Check for AutoCAD
Err.Clear()
' AvDbDocument
dbxDoc = AcadApp.GetInterfaceObject("ObjectDBX.AxDbDocument.16")
' Opening Temp1.dwg
Dim dwgName As String = "D:\Temp\Temp1.dwg"
dbxDoc.Open(dwgName)
' Blocks collection
Dim str As String = ""
Dim blks As AcadBlocks
blks = dbxDoc.Blocks
MsgBox(CStr(blks.Count), MsgBoxStyle.Information, _
"Number of blocks")
Dim bk As AcadBlock
For Each bk In blks
str += bk.Name & Chr(13)
Next
MsgBox(str, MsgBoxStyle.Information, "Blocks")
' Model Space
Dim msp As AcadModelSpace
msp = dbxDoc.ModelSpace
MsgBox(CStr(msp.Count), MsgBoxStyle.Information, _
"Number of entities in model")
AcadApp.Quit();
End Sub
End Class
Nikolay Poleshchuk
”Boost
