I have scenario where user can open the drawing using filepath like given below
Application.DocumentManager.Open(filePath, IsReadOnly);
And it is working fine.
I should allow to open the file, if file is already opened state.
Please guide me, how i can achive same
Raman
@RamanSBV wrote:
...I should allow to open the file, if file is already opened state...
Opened with this AutoCAD session or opened with other AutoCAD session? Opened on this PC or opened from network?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Sorry Yeh....
I should not allow user to open same file, if file is already in Opened on this PC.
Raman
So allow or not allow? I no longer understand you. Describe a scenario clearly paragraph by paragraph.
I should not allow user to open the same file again, if file is in opend state. by current session
Raman
Now I understand.
Enough to compare the full path to the file with all full pathes of Documents in Application.DocumentManager and if fullpath found then do not open file, but switch Application.DocumentManager.MdiActiveDocument to founded with full path Document.
I got it what i want
Using below code.
DocumentCollection docs = Application.DocumentManager;
foreach (Document doc in docs)
if (doc.Name == filePath)
return true;
Thankyou very much
Raman
I hope filePath is a full path to file. Also it will be right to compare paths uppercases (or lowercases).
P.S.: By the way for thanking on this forum there is a Kudos and Accept solution.
And code have to be posted with Insert Code button.
