• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Accepted Solution
    How to check BlockReference
    164 Views, 3 Replies
    01-03-2013 03:54 AM
    HI all.
    So i have 3 file DWG :
    3.dwg : is a plan 'archi'
    2.dwg is a plan with only décoration.
    1. dwg is a plan with only the water.
    i have this structure in my file (1.dwg) :
    1.dwg
    ---> 2..dwg
    ---------> 3.dwg   (this file is a Xref of 2.dwg)
    --> is the blockRefecence (XRef).
    my code :
            Dim CollXref As New ObjectIdCollection
            Dim mydb As Database = Application.DocumentManager.MdiActiveDocument.Database
            Dim myTrans As Transaction = mydb.TransactionManager.StartTransaction
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim DocLock As DocumentLock = doc.LockDocument
            Try
                Dim BlocTable As BlockTable = CType(myTrans.GetObject(mydb.BlockTableId, OpenMode.ForRead), BlockTable)
                For Each btid As ObjectId In BlocTable
                    Dim DefBloc As BlockTableRecord = CType(myTrans.GetObject(btid, OpenMode.ForWrite), BlockTableRecord)
                    If DefBloc.IsFromExternalReference = True Then
                        If DefBloc.IsResolved = False Then
                        Else
                            CollIdXref.Add(btid)
                Next
                myTrans.Commit()
            Catch ex As Exception
                MsgBox(ex.Message, vbOKOnly & vbCritical, "ee")
            Finally
                myTrans.Dispose()
            End Try
            DocLock.Dispose()
            DocLock = Nothing
    So i don't want to add Id of a Xref From a Xref. (In my example i want only ObjectId of the 2.dwg not 3.dwg if i launch this code on 1.dwg.
    How i can do that ?
    Please use plain text.
    Member
    Re: How to check BlockReference
    01-04-2013 02:14 PM in reply to: AubelecBE
    You can use the XRef Graph to determine if an XRef is nested. Here is a blog post that shows how to use the XRefGraph type:
    http://adndevblog.typepad.com/autocad/2012/06/finding-all-xrefs-in-the-current-database-using-cnet.h...
    Cheers
    Gopinath
    01-05-2013 02:56 AM in reply to: gopinatht
    Thx i have to see that
    01-06-2013 02:43 AM in reply to: AubelecBE
    Here my code final :
                    Dim LockDoc As DocumentLock = doc.LockDocument
                    Dim OkErr as boolean = false
                    Dim CollXRef As New ObjectIdCollection
                    Do
                        CollXRef.Clear()
                        Dim xg As XrefGraph = db.GetHostDwgXrefGraph(True)
                        Dim root As GraphNode = xg.RootNode
                        Using tr As Transaction = db.TransactionManager.StartTransaction
                            For o = 0 To root.NumOut - 1 Step 1
                                Dim child As XrefGraphNode = CType(root.Out(o), XrefGraphNode)
                                If child.XrefStatus = XrefStatus.Resolved Then
                                    Dim bl As BlockTableRecord = tr.GetObject(child.BlockTableRecordId, OpenMode.ForRead)
                                    'ed.WriteMessage(vbCrLf & i_indent + child.Database.Filename)
                                    ' Name of the Xref (found name)
                                    ' You can find the original path too:
                                    If bl.IsFromExternalReference = True Then
                                        ed.WriteMessage(vbCrLf & "Xref path name: " + bl.PathName)
                                        CollXRef.Add(bl.ObjectId)
                                        Exit For
                            Next
                            'trouvé un xref --> Adding
                            If CollXRef.Count > 0 Then
                                Try
                                    doc.Database.BindXrefs(CollXRef, False)
                                    okErr = True
                                    MsgBox("Erreur lors de la liaison d'un Xref" & vbCrLf & "--> Essayer de lier le premier niveau", _
                                                  vbOKOnly & vbCritical, _
                                                  "Erreur Système")
                                Finally
                                    tr.Commit()
                                End Try
                        End Using
                        ed.WriteMessage(vbCrLf & "-> " & CollXRef.Count.ToString)
                    Loop Until (CollXRef.Count = 0) Or (okErr = True)
                    LockDoc.Dispose()
                    LockDoc = Nothing
     If check only one XRef. it is for the binf of only one XREF.
    I have big file to bing and if i bing all in one troke, autocad crack for a 'Out of mémory'
    I can't check it now (i am not on my work). So i don't know if i have resolve this case of out of memory.
