.NET
How to change object from context menu?
3 REPLIES 3
pva75
954 Views, 3 Replies
According to this http://adndevblog.typepad.com/autocad/2012/05/object-specific-context-menu-using-net.html article I tried to add context menu to my object:
ContextMenuExtension nodeContextMenu = new ContextMenuExtension();
Application.AddObjectContextMenuExtension(RXClass.GetClass(typeof(DBPoint)), nodeContextMenu);
Next, I found selected object:
private static ObjectId GetSelectedObject()
  Document doc = Application.DocumentManager.MdiActiveDocument;
  Editor ed = doc.Editor;
  PromptSelectionResultacSSPrompt = ed.SelectImplied();
  if (acSSPrompt.Status != PromptStatus.OK)
         return  ObjectId.Null;
  SelectionSetset = acSSPrompt.Value;
  ObjectId[] ids = set.GetObjectIds();
  if(ids.Length != 1)
     returnObjectId.Null;
  returnids[0];
Ok, I found it and tried to change properties of selected object:
using (Transactiontx = db.TransactionManager.StartTransaction())
  DBPoint point = tx.GetObject(selectedObject, OpenMode.ForWrite) asDBPoint;
At this line Autocad has been crashed.
This line works if I open object ForRead, but I can't open it ForWrite or call
UpgradeOpen.
Is it possible to change object from context menu?
Pavel.
3 REPLIES 3
_gile
in reply to: pva75
By my side, I define two separated classes:
- a class for the context menu with two static methods: Attach() and Detach() to add or remove the context menu and the MenuItem.Click() event handler which calls a command
- a class implementing IextensionApplication to add the context menu at startup in which the command is defined. The command uses the UsePickSet CommandFlag and some PromptSelectionSettings so that it works with a single entity and can be used from the command line or from the context menu.
Here's a little sample:
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Windows;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace PointEdit
    public class Commands : IExtensionApplication
        public void Initialize()
            ContextMenu.Attach();
        public void Terminate()
            ContextMenu.Detach();
        [CommandMethod("PointEdit", CommandFlags.UsePickSet)]
        public void PointEdit()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            TypedValue[] filter = new TypedValue[1] { new TypedValue(0, "POINT") };
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.SingleOnly = true;
            pso.SinglePickInSpace = true;
            pso.SelectEverythingInAperture = true;
            pso.RejectObjectsOnLockedLayers = true;
            PromptSelectionResult psr;
            do
                psr = ed.GetSelection(pso, new SelectionFilter(filter));
                if (psr.Status != PromptStatus.OK) return;
            } while (psr.Value.Count > 1);
            using (Transaction tr = db.TransactionManager.StartTransaction())
                DBPoint pt = (DBPoint)tr.GetObject(psr.Value.GetObjectIds()[0], OpenMode.ForWrite);
                pt.Color = Color.FromColorIndex(ColorMethod.ByAci, 30);
                tr.Commit();
    class ContextMenu
        private static ContextMenuExtension cme;
        internal static void Attach()
            cme = new ContextMenuExtension();
            MenuItem mi = new MenuItem("PointEdit");
            mi.Click += new EventHandler(Edit);
            cme.MenuItems.Add(mi);
            RXClass rxc = Entity.GetClass(typeof(DBPoint));
            AcAp.AddObjectContextMenuExtension(rxc, cme);
        internal static void Detach()
            AcAp.RemoveObjectContextMenuExtension(rxc, cme);
        private static void Edit(object sender, EventArgs e)
            doc.SendStringToExecute("POINTEDIT ", true, false, true);
Gilles Chanteau
GileCAD
GitHub
pva75
in reply to: _gile
Thanks!
I did as you said and it woks fine (also I send paramaters by doc.UserData).
Pavel.
Hallex
in reply to: pva75
Here is one more toy to play with your points:
        using Autodesk.AutoCAD.Geometry;
        using Autodesk.AutoCAD.Interop.Common;
        using Autodesk.AutoCAD.Interop;
        //____________________________________________________//
            PromptSelectionResult acSSPrompt = ed.SelectImplied();
            SelectionSet set = acSSPrompt.Value;
            if (ids.Length != 1)
            return ids[0];
        [CommandMethod("PTE", CommandFlags.UsePickSet)]
        public static void EditPoint()
            ObjectId id = ObjectId.Null;
            using (Transaction tx = db.TransactionManager.StartTransaction())
                 id = GetSelectedObject();
                 if (id == ObjectId.Null)
                     Application.ShowAlertDialog("Select object first!");
                     return;
                Entity ent = tx.GetObject(id, OpenMode.ForRead, false) as Entity;
                // check if DBPoint is selected
                if (!id.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(DBPoint))))
                    Application.ShowAlertDialog("You have to select a Point object only!");
                    return;
                DBPoint point = ent as DBPoint;
                point.UpgradeOpen();
                // do you mojo here
                point.ColorIndex = 121;
                tx.Commit();
        //  written by Alexander Rivilis
        [CommandMethod("MyTool")]
        static public void AddToolbar()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            try
                AcadDocument acdoc = doc.AcadDocument as AcadDocument;
                AcadApplication acad = (AcadApplication)acdoc.Application;
                IAcadMenuGroups pMnuGrps = acad.MenuGroups;
                int nums = pMnuGrps.Count;
                IAcadMenuGroup pMnuGrp = pMnuGrps.Item(nums - 1);
                AcadToolbars pTlbrs = pMnuGrp.Toolbars;
                IAcadToolbar pTlbr = pTlbrs.Add("Modify toolbar");
                IAcadToolbarItem pTlbrItem = pTlbr.AddToolbarButton(
                0, // Item number
                "Mocoro", // Item name
                "Move Copy Rotate", // Item help string
                "\x1b\x1b_.MOCORO " // Item macro string
                pTlbrItem.SetBitmaps("et_MOCORO16.bmp", "et_MOCORO24.bmp");
                1, // Item number
                "CopyM", // Item name
                "Copy Multiple", // Item help string
                "\x1b\x1b_.COPY " // Item macro string
                pTlbrItem.SetBitmaps("et_COPYM16.bmp", "et_COPYM24.bmp");
               2, // Item number
               "Stretch", // Item name
               "Stretch", // Item help string
                 "\x1b\x1b_.STRETCH " // Item macro string
                pTlbrItem.SetBitmaps("et_MSTRCH16.bmp", "et_MSTRCH24.bmp");
              2, // Item number
              "Point Edit", // Item name
              "Edit point color", // Item help string
              "\x1b\x1b_.PTE " // Item macro string    // <--- "PTE" is your command name within the same project   --->
                pTlbrItem.SetBitmaps("et_SHWURL16.bmp", "et_SHWURL24.bmp");
                // ad separators around the button
                IAcadToolbarItem pTlbrSep1 = pTlbr.AddSeparator(pTlbr.Count - 2);
                IAcadToolbarItem pTlbrSep2 = pTlbr.AddSeparator(pTlbr.Count - 1);
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                ed.WriteMessage(ex.Message);
~'J'~
”Boost
