AlignmentPoint will always be (0,0,0) for Left justified text. For any other justification it will have a value. Note the return of a simple test command:
Select normal left justified Text object:
Select MiddleCenter justified text:
First text object's Position & alignment points: (782.848598480457,5330.0457627218,0), (0,0,0)
Second text object's Position & alignment points: (782.539234103324,5326.01723791071,0), (784.372567436658,5326.51723791071,0)
And here is the example code:
[CommandMethod("TextTest")]
public void texttest()
ed = Application.DocumentManager.MdiActiveDocument.Editor;
PromptEntityOptions entOpts = new PromptEntityOptions("\nSelect normal left justified Text object:");
entOpts.SetRejectMessage("...not a Text object.");
entOpts.AddAllowedClass(typeof(DBText), true);
PromptEntityResult entRes = ed.GetEntity(entOpts);
if (entRes.Status != PromptStatus.OK)
return;
using (Transaction tr = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction())
DBText text1 = (DBText)tr.GetObject(entRes.ObjectId, OpenMode.ForRead);
entOpts.Message = "\nSelect MiddleCenter justified text:";
return;
DBText text2 = (DBText)tr.GetObject(entRes.ObjectId, OpenMode.ForRead);
ed.WriteMessage("\nFirst text object's Position & alignment points: {0}, {1}", text1.Position.ToString(), text1.AlignmentPoint.ToString());
ed.WriteMessage("\nSecond text object's Position & alignment points: {0}, {1}", text2.Position.ToString(), text2.AlignmentPoint.ToString());
tr.Commit();
