• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    How to capture double click event in AutoCAD using VB.NET
    709 Views, 28 Replies
    11-26-2012 06:16 PM
    Hi all,
    I`m still trying to find a solution to my previous post, displaying a vb.net form when an autocad block reference is double-clicked. Unfortunately, I still don`t know how to capture the double-click event for a block reference from code. I have gone down the IMessageFilter path, still no success.
    I have tried the addHandler for application using code supplied to me in my previous post, still no luck. I really need to be able to capture the doubleclick event for a block reference in autocad, without overwriting the default autocad double-click behavior.
    I wish to be able to double-click a block reference, capture its name, and, if the name is same as blocks created by my form, then I`d simply have my dot net form pop up, displaying a few of the block`s properties.
    Does anyone have any ideas on how this might be accomplishedÉ
    Below is the code module I am using, which isn`t working ofr me:
    ' System
    Imports Microsoft.Win32
    Imports System.Reflection
    ' AutoCAD
    Imports Autodesk.AutoCAD.ApplicationServices
    Imports Autodesk.AutoCAD.Runtime
    Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.EditorInput
    ' AutoCAD Interop
    Imports acOp = Autodesk.AutoCAD.Interop
    Imports acOpCom = Autodesk.AutoCAD.Interop.Common
    Module ModDoubleClick
    Private acDoc As acOp.AcadDocument
    Private handlerAdded As Boolean = False
    Public Sub eventDoubleClick()
        Try
            If handlerAdded = False Then
                acApp.SetSystemVariable("DBLCLKEDIT", 0)
                If acDoc Is Nothing Then
                    acDoc = CType(acApp.DocumentManager.MdiActiveDocument.AcadDocument, _
                    Autodesk.AutoCAD.Interop.AcadDocument)
                    AddHandler acDoc.BeginDoubleClick, AddressOf callback_DoubleClick
                End If
                handlerAdded = True
            End If
        Catch ex As Autodesk.AutoCAD.Runtime.Exception
            MsgBox(ex.Message, MsgBoxStyle.Critical)
        Finally
            acApp.SetSystemVariable("DBLCLKEDIT", 1)
        End Try
    End Sub
    Private Sub callback_DoubleClick(ByVal PickPoint As Object)
        Dim activeDoc As Document = acApp.DocumentManager.MdiActiveDocument
        Dim prmtSel As PromptSelectionResult = activeDoc.Editor.GetSelection()
        Using docLock As DocumentLock = activeDoc.LockDocument()
            If prmtSel.Status <> PromptStatus.OK Then Return
            If prmtSel.Value.Count <> 1 Then Return
            Dim id As Autodesk.AutoCAD.DatabaseServices.ObjectId = _
            prmtSel.Value(0).ObjectId
            Using acTrans As Autodesk.AutoCAD.DatabaseServices.Transaction = _
            activeDoc.TransactionManager.StartTransaction()
                Dim dbObj As Autodesk.AutoCAD.DatabaseServices.DBObject = _
                acTrans.GetObject(id, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
                Dim ent As Autodesk.AutoCAD.DatabaseServices.Entity = _
                TryCast(dbObj, Autodesk.AutoCAD.DatabaseServices.Entity)
                If ent Is Nothing Then
                    Return
                Else
                    Dim blockRef As Autodesk.AutoCAD.DatabaseServices.BlockReference = _
                    TryCast(ent, Autodesk.AutoCAD.DatabaseServices.BlockReference)
                    If blockRef Is Nothing Then
                        Return
                    Else
                        activeDoc.Editor.WriteMessage(blockRef.Name)
                    End If
                End If
                acTrans.Commit()
            End Using
        End Using
    End Sub
    End Module
    And the Commands class, from which my vb.net form is generated, as well as where the ModDoubleClick.eventDoubleClick() method is called:
    Public Class Commands
        ' Component for displaying the Mass Straight Conveyor form
        <CommandMethod("mst")> _
        Public Shared Sub massStraight()
            Try
                ' Call this to override default block dblclk event handler
                ' Display the mass straight form
                Dim cForm As New frmMassStraight
                acApp.ShowModalDialog(cForm)
            End Try
        End Sub
    End Class
    Any help is greatly appreciated!
    Many thanks...
    Cat
    Please use plain text.
    Distinguished Contributor
    ACADuser
    Re: How to capture double click event in AutoCAD using VB.NET
    11-27-2012 06:58 AM in reply to: mindofcat
    See if this might help;
    http://www.theswamp.org/index.php?topic=40021.0
    ACADuser
    Dell Precision T5500 Workstation
    Windows XP Professional SP3
    Dual Quad Core Intel Xeon Processors E5540 2.53GHz,8M L3,5.8GT/s,turbo
    4GB, DDR3 Memory, 1066MHz, ECC (4 DIMMS)
    1.5GB NVIDIA Quadro FX 4800, DUAL MON, 2DP & 1DVI
    160GB, 3.0Gb/s, 16MB Data Burst Cache,SATA2,10K RPM Hard Drive
    16XDVD AND 16XDVD+/-RW
    Active Contributor
    11-27-2012 07:30 AM in reply to: mindofcat
    This code seems to be working OK for me as far as capturing the event.  You are creating and displaying the form at the wrong place however.  I think these 2 lines of code shouldn't be part of your command that's setting up the handler:
    but instead have to be called before your callback returns.  If you try to run this but you double click on something other than a block reference you might Return prematurely.  I would suggest you print out the Type of your entity just to be sure you are double clicking on the right entity before you return:
    ed.WriteMessage(vbLf & "Type:        " + ent.GetType().ToString())
    You should see:
    Type:        Autodesk.AutoCAD.DatabaseServices.BlockReference
    as opposed to something like this:
    Type:        Autodesk.AutoCAD.DatabaseServices.Solid3d
    or something else.  Hope this helps
    11-27-2012 08:31 AM in reply to: sszabo
    Active Contributor
    11-27-2012 12:14 PM in reply to: ACADuser
    Thanks... the article shows me a code structure that is quite similar to the one I already have. My code should work, but it isn't, I am not seeing the desired result, and I'm guessing this is probably as a result of HOW I'm calling its command.
    This whole thing is so confusing. I even seperated the doubleclick module into its own calling command (complete with usepickset), so that I could draw a block, then execute the doubleclick command, and then double-click on the block to see if anything happens... nothing. Just the same ol' AutoCAD attributes editor.
    Really frustrating!
    Active Contributor
    11-27-2012 12:20 PM in reply to: jeff
    And as well, I have also been to http://adndevblog.typepad.com/autocad/2012/09/displaying-entity-details-on-double-click.html many days ago; I translated the code to dot net, and executed it. When I go to AutoCAD and type cui in the command to pull up the cui editor, I see that my new double click action has been created alright, but I still don't know how to attach it to block references, or how to modify the macro string to open my vb.net form.
    The macro string in the article runs thus:
    C^C^myForm
    How does this get modified to pop up a vb.net form named frmMassStraight which I would normally open using application.showModalDialog(formInstance)
    Thanks all, for your help, but I'm still floundering in the dark, trying so hard to see the light which I know exists at the end of this dark tunnel...
    Active Contributor
    11-27-2012 12:27 PM in reply to: mindofcat
    Does anyone know of any professional AutoCAD VB.NET Customization Consultants whom I can pay for their time in order to discuss this doubleclick action problem on the phone or via email, in the hope of finding a feasible solution?
    Many thanks in advance...
    Cat
    Active Contributor
    11-27-2012 12:35 PM in reply to: mindofcat
    I am not sure I understand what is the problem.. Your code works perfectly with minor changes.
    I replaced your cForm with one that has a textbox1 that displays all the properties of the objects you double click.  It should help you identify/discover any issues.  Alll you should have to do is add a winform to your project and drag a textbox1 on it:
     Keep me posted where is your code failing exactly, because this works for me.  Also, I am using AutoCAD 2013, it should be easy to replace document code relevant to 2012 or earlier.
            Public db As Database = HostApplicationServices.WorkingDatabase
            Public ed As Editor = activeDoc.Editor
            Public ReadOnly Property ThisDrawing() As AcadDocument
                Get
                    Return DocumentExtension.GetAcadDocument(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument)
                End Get
            End Property
            Private cForm As New frmMassStraight
                Try
                        MgdAcApplication.SetSystemVariable("DBLCLKEDIT", 0)
                            acDoc = CType(ThisDrawing, Autodesk.AutoCAD.Interop.AcadDocument)
                        End If
                        handlerAdded = True
                    End If
                Finally
                    MgdAcApplication.SetSystemVariable("DBLCLKEDIT", 1)
                End Try
            End Sub
            Private Sub DisplayError(ByVal msg As String)
                ed.WriteMessage(vbLf + msg)
                cForm.TextBox1.Text += msg + vbCrLf
                MgdAcApplication.ShowModalDialog(cForm)
            End Sub
                Dim msg As String = ""
                        DisplayError(String.Format("ERROR: prmtSel.Status= {0}", prmtSel.Status))
                        Return
                    End If
                        DisplayError(String.Format("ERROR: prmtSel.Value.Count={0}", prmtSel.Value.Count))
                        Return
                    End If
                    Dim id As Autodesk.AutoCAD.DatabaseServices.ObjectId = prmtSel.Value(0).ObjectId
                    Try
                            cForm.Text = ent.GetType().ToString()
                            For Each p As System.Reflection.PropertyInfo In ent.GetType().GetProperties()
                                Try
                                    Dim displStr As String = String.Format("  {0}:     '{1}'", p.Name, p.GetValue(ent, Nothing))
                                    cForm.TextBox1.Text += displStr + vbCrLf
                                Catch
                                    Dim msgStr As String = String.Format("ERR: '{0}' p='{1}'", Err.Description, p.ToString)
                                    ed.WriteMessage(vbLf + msgStr)
                                    cForm.TextBox1.Text += msgStr + vbCrLf
                                End Try
                            Next
                                DisplayError(String.Format("ERROR: ent={0}", ent))
                                Return
                            Else
                                    DisplayError(String.Format("ERROR: blockRef={0}", blockRef))
                                    Return
                                Else
                                    activeDoc.Editor.WriteMessage(blockRef.BlockName)
                                End If
                            End If
                            acTrans.Commit()
                        End Using
                        Dim msgStr As String = String.Format("EX: '{0}'", ex.ToString)
                    Catch
                        Dim msgStr As String = String.Format("ERR: '{0}'", Err.Description)
                    End Try
                End Using
            End Sub
            Public Sub massStraight()
                Try
                    eventDoubleClick()
                End Try
            End Sub
    Active Contributor
    11-27-2012 01:41 PM in reply to: sszabo
    Thanks a bunch. Let me try out your suggestion, and see if I can pinpoint where I am making my mistake.
    I shall keep you posted on the development.
    Many thanks...
    Active Contributor
    11-27-2012 07:21 PM in reply to: sszabo
    Hi sszabo,
    I`ve implemented the code revision you so kindly provided. However, when I run the `mst` command, nothing happens. I doubleclick on a block after running the command, and the attributes editor is what I see still.
    Here is the code I have:
    ' System
    Imports System
    Imports System.Collections.Generic
    Imports System.Linq
    Imports System.Text
    Imports System.Linq.Expressions
    ' AutoCAD
    ' AutoCAD Interop
    <Assembly: CommandClass(GetType(Test.Commands))>
    Namespace Test
            Public activeDoc As Document = acApp.DocumentManager.MdiActiveDocument
            Private cForm As New frmMassStraight ' I already have a form called frmMassStraight, so I simply added a Textbox1 to it
            ' I tried using the property call, but was getting an error on type mismatch from document to acadDocument
            Public Function ThisDrawing()
                Return acApp.DocumentManager.MdiActiveDocument.AcadDocument
            End Function
                Try
                        End If
                        handlerAdded = True
                    End If
                Finally
                End Try
            End Sub
            Private Sub displayError(ByVal msg As String)
            End Sub
            Private Sub callback_DoubleClick(ByVal pickPoint As Object)
                        displayError(String.Format("Error: prmtSel.Status= {0}", prmtSel.Status))
                        Return
                    End If
                        displayError(String.Format("Error: prmtSel.Value.Count={0}", _
                    End If
                    Try
                            For Each p As System.Reflection.PropertyInfo In _
                                Try
                                    Dim displStr As String = String.Format(" {0}:      '{1}'", _
                                Catch
                                    Dim msgStr As String = String.Format("Error: '{0}' p='{1}'", _
                                End Try
                            Next
                                displayError(String.Format("Error: ent={0}", ent))
                                Return
                            Else
                                    displayError(String.Format("Error: blockRef={0}", blockRef))
                                    Return
                                Else
                                End If
                            End If
                            acTrans.Commit()
                        End Using
                    Catch
                        Dim msgStr As String = String.Format("ERR: '{0}", Err.Description)
                    End Try
                End Using
            End Sub
                Try
                    ' Call this to override the default block dblclk event handler
                    eventDoubleClick()
                End Try
            End Sub
        End Class
    End Namespace
    I wonder if the problem is because I used the wrong document translations here. I am developing in an AutoCAD 2010 environment, and probably used the wrong instances for your equivalent of DocumentExtension.GetAcadDocument() as well as MgdAcApplication.
    As it is, this code should work, but I am not seeing the desired effect. The form doesn`t pop up at all, so I can`t even tell what`s wrong. However, in an attempt to debug, I am guessing that the showModalDialog code at the end of the doubleclick callback probably isn`t being reached at all, which is why the form does not pop up at all to show me anything.
    Not even the commandline shows me any of the messages I am supposed to see in the event of an error, or successful call.
    Any ideas,
    Thanks in advance...
