.NET
How to cancel active command?
6 REPLIES 6
4769 Views, 6 Replies
I have an active command that I want to cancel, how can I do this? Right
now I'm working with 3dorbit, if that makes a difference.
Thanks in advance.
Tim
"A blind man lets nothing block his vision."
6 REPLIES 6
http://through-the-interface.typepad.com/through_the_interface/2006/08/cancelling_an_a.html
It seems that I would have to use the undocumented acedPostCommand(), but
how would I in C#? I think this is usually called in Arx.
Thanks.
Tim
wrote in message news:5327794@discussion.autodesk.com...
I found a way from one of Tony's post, and it seems to be working.
Tim
"T.Willey" wrote in message
news:5327843@discussion.autodesk.com...
Thanks.
Tim
JanetDavidson
Hello Tim,
Could you please share your finding? I have the same problem. I want to cancel a  command pragmatically.
Basically sending Escape to command prompt. But don't want to use sendstring.
Hopefully you won't be disappear like Tony did . I searched for his post regarding this and not found anything.
Janet.
in reply to: JanetDavidson
Take a look at HostApplicationServices.UserBreak Method
JanetDavidson
Hey Old Friend.
Thanks . You are really a gentle man.
This is the result of my finding based on your suggestion
            If HostApplicationServices.Current.UserBreak() Then Throw New Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.UserBreak, "ESCAPE pressed") End If
correct me if I am wrong Jeff. This is good to catch if user press Escaped.
But I need to send the EScape to  Command in action / in progress.
So basically either I don't know how to use this method , or  there is some misunderstanding.
You are a man any lady wish . So caring.
Cheers.
Janet.
”Boost
