.NET
Member
Message 1 of 4 (570 Views)
How to add new AttibuteDefinition newly? (C#, Object ARX)
570 Views, 3 Replies
07-11-2012 02:48 AM
Hey Everyone,
I'd like to just add 'Attibute Definition' on the fly by my external program.
'Attibute Definition' seems like a Text(MTEXT) Object in AutoCAD screen, doesn't it?
I implemented the source below. However, nothing is added.
DWF file I opended doesn't have any Blocks and other Objects.
What's wrong with this code?
Here's a source code. Make method with this routine and try.
public static void AddAttibuteDefinition(string attName, string prompt, string tag, string value)
  // At first, Get current AutoCAD Document and Databese
  Document curDoc = Application.DocumentManager.MdiActiveDocument;
  Database curDB = curDoc.Database;
  using (DocumentLock docLock = curDoc.LockDocument())
   // Start transacition
    using (Transaction trans = curDB.TransactionManager.StartTransaction())
     // Open BlockTable
      BlockTable blockTbl = (BlockTable)trans.GetObject(curDB.BlockTableId, OpenMode.ForWrite);
      // Get BlockTableRecord
     ObjectId modelSpaceID = blockTbl[BlockTableRecord.ModelSpace];
     BlockTableRecord blockTblRec = (BlockTableRecord)trans.GetObject(modelSpaceID, OpenMode.ForWrite);
      blockTblRec.UpgradeOpen();
      // Get BlockRefference
     BlockReference blockRef = new BlockReference(Point3d.Origin, blockTblRec.Id);
     BlockTableRecord modelSpace = (BlockTableRecord)trans.GetObject(modelSpaceID, OpenMode.ForWrite);
      modelSpace.AppendEntity(blockRef);
     trans.AddNewlyCreatedDBObject(blockRef, true);
      // Create AttriuteDefine
      Point3d position = new Point3d(Point3d.Origin.X, Point3d.Origin.Y, Point3d.Origin.Z);
     AttributeDefinition name_def = new AttributeDefinition(position, attName, tag, prompt, modelSpaceID);
      // Create AttributeReference
      AttributeReference name_ref = new AttributeReference();
      name_ref.SetAttributeFromBlock(name_def, Matrix3d.Identity);
      name_ref.TextString = "SampleName";
      // Add AttributeReference into BlockReference
      blockRef.AttributeCollection.AppendAttribute(name_ref);
      trans.AddNewlyCreatedDBObject(name_ref, true);
      // Commit transaction
      trans.Commit();
I've seen various codes, however those codes are assumed that Block with attribute has been existed.
I'm developing with Visual Studio 2010 (C#) and Object ARX.
Any advice would be greatly appreciated.
*Expert Elite*
Hallex
Message 2 of 4 (567 Views)
Re: How to add new AttibuteDefinition newly? (C#, Object ARX)
07-11-2012 04:12 AM in reply to: Daikichi
Try this working code, sorry no explanation about theory
        [CommandMethod("blkonfly")]
        public static void CreateBlockMark()
            // Get the current document and database
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            // Start a transaction
            using (Transaction tr = db.TransactionManager.StartTransaction())
                try
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                    string blkName = "BLDG_MARK";
                    if (bt.Has(blkName))
                        ed.WriteMessage("\nBlock \"BLDG_MARK\" already exist.");
                        return;
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Point3d inspt = new Point3d(0, 0, 0);
                    BlockTableRecord newBtr = new BlockTableRecord();
                    bt.Add(newBtr);
                    newBtr.Name = blkName;
                    newBtr.Origin = inspt;
                    newBtr.BlockScaling = BlockScaling.Uniform;
                    newBtr.Units = UnitsValue.Inches;
                    newBtr.Explodable = true;
                    tr.AddNewlyCreatedDBObject(newBtr, true);
                    Polyline pline = new Polyline();
                    Point2dCollection pts = new Point2dCollection()
                    { new Point2d(2.454, 3.4631),
                        new Point2d(1.991, 2.908),
                        new Point2d(1.991, 0),
                        new Point2d(-1.991, 0),
                    new Point2d (-1.991,  2.908),
                    new Point2d (-2.454,  3.4631),
                    new Point2d (0, 5.0096)
                    int i = 0;
                    foreach (Point2d pt in pts)
                        pline.AddVertexAt(i, pt, 0, 0, 0);
                        i += 1;
                    pline.Closed = true;
                    pline.Layer = "0";
                    pline.LinetypeId = db.ContinuousLinetype;
                    pline.ColorIndex = 0;
                    pline.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0);
                    newBtr.AppendEntity(pline);
                    tr.AddNewlyCreatedDBObject(pline, true);
                    AttributeDefinition attr = new AttributeDefinition();
                    attr.Layer = "0";
                    attr.LinetypeId = db.ContinuousLinetype;
                    attr.ColorIndex = 0;
                    attr.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0);
                    attr.Tag = "BLDG_NUMBER";
                    attr.Prompt = "Building number:";
                    attr.TextString = "900";
                    attr.Preset=false;
                    //attr.TextStyle = db.Textstyle;//<--   A2009
                    attr.TextStyleId = db.Textstyle;//<--   A2010
                    attr.Height = 1.0;
                    attr.Position = new Point3d(0, 1.0574, 0);
                    attr.Justify = AttachmentPoint.MiddleCenter;
                    attr.AlignmentPoint = new Point3d(0, 1.0574, 0);
                    attr.LockPositionInBlock = true;
                    attr.AdjustAlignment(db);
                    newBtr.AppendEntity(attr);
                    tr.AddNewlyCreatedDBObject(attr, true);
                    AttributeDefinition attr2 = new AttributeDefinition();
                    attr2.Layer = "0";
                    attr2.LinetypeId = db.ContinuousLinetype;
                    attr2.ColorIndex = 0;
                    attr2.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0);
                    attr2.Tag = "BLDG_CODE";
                    attr2.Prompt = "Building code:";
                    attr2.TextString = "DM1000";
                    attr2.Preset = false;
                    attr2.TextStyleId = db.Textstyle;//<--   A2010
                    attr2.Height = 1.0;
                    attr2.Position = new Point3d (0, 6.0678, 0);
                    attr2.Justify = AttachmentPoint.MiddleCenter;
                    attr2.AlignmentPoint = new Point3d(0, 6.0678, 0);
                    attr2.LockPositionInBlock = true;
                    attr2.AdjustAlignment(db);
                    newBtr.AppendEntity(attr2);
                    tr.AddNewlyCreatedDBObject(attr2, true);
                    AttributeDefinition attr3 = new AttributeDefinition();
                    attr3.Layer = "0";
                    attr3.LinetypeId = db.ContinuousLinetype;
                    attr3.ColorIndex = 0;
                    attr3.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0);
                    attr3.Tag =  "BLDG_MARK";
                    attr3.Prompt =  "Building mark:";
                    attr3.TextString = "M";
                    //attr.Verifiable = true;
                    attr.Preset = false;
                    attr3.TextStyleId = db.Textstyle;//<--   A2010
                    attr3.Height = 1.0;
                    attr3.Position = new Point3d (2.7165, 4.5163, 0);
                    attr3.Justify = AttachmentPoint.MiddleCenter;
                    attr3.AlignmentPoint = new Point3d (2.7165, 4.5163, 0);
                    attr3.LockPositionInBlock = true;
                    attr3.AdjustAlignment(db);
                    newBtr.AppendEntity(attr3);
                    tr.AddNewlyCreatedDBObject(attr3, true);
                    tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Member
Message 3 of 4 (561 Views)
07-11-2012 06:01 AM in reply to: Hallex
Hi,  Hallex.
Thank you for showing for your useful reference code.
It works!  That's exactly what I want.
I'll interpret  the code carefully.
I really appreciate it.
*Expert Elite*
Hallex
Message 4 of 4 (555 Views)
07-11-2012 07:16 AM in reply to: Daikichi
Glad to help,
Show us your attempt if you've finish it
Cheers :smileyhappy:
~'J'~
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
