.NET
Valued Contributor
RamanSBV
Message 1 of 6 (800 Views)
How to add .ctb file to drawing file.
800 Views, 5 Replies
08-27-2012 12:46 AM
Please guide me on
1. adding .ctb file to drawing file.
Raman
Alfred.NESWADBA
Message 2 of 6 (799 Views)
Re: How to add .ctb file to drawing file.
08-27-2012 12:50 AM in reply to: RamanSBV
does >>>that<<< help?
- alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 3 of 6 (789 Views)
08-27-2012 02:51 AM in reply to: Alfred.NESWADBA
Thanks for your response......
Could you please me, on getting using
plot style file path.
Raman
Alfred.NESWADBA
Message 4 of 6 (787 Views)
08-27-2012 02:58 AM in reply to: RamanSBV
it should not be necessary that you assign a plotstyle-path to your CTB as this is defined under options of AutoCAD. AutoCAD knows itself where to find CTB/STB-files. If yours is not in the path for plotstyles you have to copy it into the folder defined to hold plotstyle-files.
- alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 5 of 6 (786 Views)
08-27-2012 03:05 AM in reply to: Alfred.NESWADBA
Yes, I agree on you.
But I need to export drawing file along with plot style to some other server.
So, I need to know the file path of plot style that is using by drawing file.
Rama
Alfred.NESWADBA
Message 6 of 6 (784 Views)
08-27-2012 03:19 AM in reply to: RamanSBV
E.g. COM-based you get the path where your plotstyles are stored with that code.
      AcadApplication.Preferences.Files.PrinterStyleSheetPath
You can also read >>>that posts<<<
- alfred -
Alfred NESWADBA
