.NET
Valued Contributor
dynamicscope
Message 1 of 10 (869 Views)
How to add a new menu in the main toolbar?
869 Views, 9 Replies
04-04-2012 12:27 AM
Hello to all.
I'm new to ObjectARX (.NET).
I would like to add a customized menu in the main toolbar.
Can't find any sample in ObjectARX 2011 samples. And it's really hard to find references.
Could I get some help, please?
Thank you.
Moderator
Alexander.Rivilis
Message 2 of 10 (858 Views)
Re: How to add a new menu in the main toolbar?
04-04-2012 03:29 AM in reply to: dynamicscope
dynamicscope wrote:
...I would like to add a customized menu in the main toolbar...
What is "main toolbar"?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
dynamicscope
Message 3 of 10 (855 Views)
04-04-2012 04:02 AM in reply to: Alexander.Rivilis
Oh. I'm sorry. I meant the menubar where "File" "Edit" "View"... sutff placed.
Moderator
Alexander.Rivilis
Message 4 of 10 (851 Views)
04-04-2012 04:37 AM in reply to: dynamicscope
OK.
1. ObjectARX SDK: samples\dotNet\CuiSamp (but only ObjectARX SDK 2008 and 2009)
2. ActiveX-interface
Valued Contributor
dynamicscope
Message 5 of 10 (829 Views)
04-04-2012 06:03 PM in reply to: Alexander.Rivilis
Following C# (VS 2008) code is what I tried with ObjectARX 2011 SDK & AutoCAD 2011.
When I debug the code it seems it runs fine. It passes throught the if statement without any error.
But I can't find the newly added menu.
Is the code wrong?
        [CommandMethod("MyGroup", "My", "MyCommandLocal", CommandFlags.Modal)]
        public void MyCommand() // This method can have any name
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            CustomizationSection cs;
            string mainCuiFile = (string)Application.GetSystemVariable("MENUNAME");
            mainCuiFile += ".cuix";
            ed.WriteMessage(mainCuiFile);
            cs = new CustomizationSection(mainCuiFile);
            if (cs.MenuGroup.PopMenus.IsNameFree("Custom Menu"))
                System.Collections.Specialized.StringCollection pmAliases = new System.Collections.Specialized.StringCollection();
                PopMenu pm = new PopMenu("Custom Menu", pmAliases, "Custom Menu Tag", cs.MenuGroup);
                PopMenuItem pmi = new PopMenuItem(pm, -1);
                pmi.MacroID = "ID_AUGI";
                pmi.Name = "Autodesk User Group International";
                pmi.MacroID = "ID_CustomSafe";
                pmi.Name = "Online Developer Center";
                foreach (Workspace wk in cs.Workspaces)
                    WorkspacePopMenu wkpm = new WorkspacePopMenu(wk, pm);
                    wkpm.Display = 1;
            else
                ed.WriteMessage("Custom Menu already Exists\n");
Moderator
Alexander.Rivilis
Message 6 of 10 (823 Views)
04-04-2012 10:07 PM in reply to: dynamicscope
cs.Save();
string flName = cs.CUIFileBaseName;
Application.SetSystemVariable("FILEDIA",0);
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("_cuiunload " + flName + " ",false,false,false);
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("_cuiload " + flName + " filedia 1 ",false,false,false);
Valued Contributor
dynamicscope
Message 7 of 10 (813 Views)
04-05-2012 02:30 AM in reply to: Alexander.Rivilis
If I add the following code, I see my newly added menu "Custom Menu" at the very end of list.
But still can't find it in the GUI menubar.
                ed.WriteMessage(wk.Name);
                foreach (WorkspacePopMenu wsPM in wk.WorkspacePopMenus)
                    PopMenu pm = cs.getPopMenu(wsPM.PopMenuID);
                    if (pm != null)
                        ed.WriteMessage(string.Format("\n{0}", pm.Name));
Thanks a lot for assisting me.
Valued Contributor
dynamicscope
Message 8 of 10 (776 Views)
04-10-2012 02:44 AM in reply to: Alexander.Rivilis
Still doesn't show up. =(
Would there be any other approach?
Moderator
Alexander.Rivilis
Message 9 of 10 (742 Views)
04-16-2012 10:21 PM in reply to: dynamicscope
Try:
SendStringToExecute("(menucmd \"Gacad.Help=+MyGroupName.MyPopUpMenuName\") ",false,false,false);
MyGroupName is a name of your's menugroup
MyPopUpMenuName is a name of your's popup-menu.
Valued Contributor
dynamicscope
Message 10 of 10 (710 Views)
04-18-2012 02:05 AM in reply to: Alexander.Rivilis
Unfortunately, the code didn't work for me. :smileysad:
However, I found the following link working.
http://through-the-interface.typepad.com/through_the_interface/2010/04/adding-to-autocads-applicatio...
The code block looks very similar to the one you taught me.
But I am not sure why only the code from the link works.
Anyway, I think my problem is finally solved.
Thank you a lot for your help.
You are not logged in.
Ask the Community
