• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    How to add a hatch pattern within rectangular boundaries in a block
    162 Views, 3 Replies
    02-28-2013 09:55 AM
    Hi folks,
    I am in the process of translating existing VBA code into its equivalent in VB.NET (developing VS Professional 2010 and testing in AutoCAD 2010)
    My problem is that I have never done hatching in VB.NET before, and now I am required to hatch a rectangular area (defined by lines) within an AutoCAD block. I have absolutely no idea how to go about accomplishing this task.
    To create my block, I am using a DBObjectCollection to store my lines, and then append them to the block definition, creating a reference to see what I just created.
    If I were to define a rectangular outline within this block, how can I possibly hatch it?
    Any pointers? Suggestions? Thanks in advance...
    Please use plain text.
    Hallex
    Re: How to add a hatch pattern within rectangular boundaries in a block
    02-28-2013 12:28 PM in reply to: mindofcat
    Here is a code to crate hatch with lines
    you have to select two opposite lines and create
    polyline to bund the area then apply hatch
    Public Sub HatchLines()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim docloc As DocumentLock = doc.LockDocument()
            Dim ed As Editor = doc.Editor
            Dim db As Database = doc.Database
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Using docloc
                Using tr
                    'ed.StartUserInteraction(Me)'<-- just in case you using this code from form button
                    Dim peo As PromptEntityOptions = New PromptEntityOptions(vbCr & "Select first line: ")
                    peo.SetRejectMessage(vbCr & "Select line only: ")
                    peo.AddAllowedClass(GetType(Line), True)
                    Dim pres As PromptEntityResult = ed.GetEntity(peo)
                    If (pres.Status <> PromptStatus.OK) Then
                        Return
                    End If
                    Dim ent As Entity = CType(tr.GetObject(pres.ObjectId, OpenMode.ForRead), Entity)
                    Dim line1 As Line = DirectCast(ent, Line)
                    If line1 Is Nothing Then
                        Return
                    End If
                    peo.Message = vbCr & "Select second line: "
                    pres = ed.GetEntity(peo)
                        Return
                    End If
                    ent = CType(tr.GetObject(pres.ObjectId, OpenMode.ForRead), Entity)
                    Dim line2 As Line = DirectCast(ent, Line)
                    If line2 Is Nothing Then
                        Return
                    End If
                    Dim sp1 As Point3d = line1.StartPoint
                    Dim ep1 As Point3d = line1.EndPoint
                    Dim sp2 As Point3d = line2.StartPoint
                    Dim ep2 As Point3d = line2.EndPoint
                    'check for line directions
                    If Math.Abs(line1.Angle - line2.Angle) >= Math.PI Then
                        'swap points if the second line has an opposite direction
                        Dim tmp As Point3d = sp1
                        sp1 = ep1
                        ep1 = tmp
                    End If
                    Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                    Dim pl As Polyline = New Polyline()
                    pl.AddVertexAt(0, New Point2d(sp1.X, sp1.Y), 0, 0, 0)
                    pl.AddVertexAt(1, New Point2d(ep1.X, ep1.Y), 0, 0, 0)
                    pl.AddVertexAt(2, New Point2d(ep2.X, ep2.Y), 0, 0, 0)
                    pl.AddVertexAt(3, New Point2d(sp2.X, sp2.Y), 0, 0, 0)
                    pl.Closed = True
                    btr.AppendEntity(pl)
                    tr.AddNewlyCreatedDBObject(pl, True)
                    Dim ids As ObjectIdCollection = New ObjectIdCollection
                    ids.Add(pl.ObjectId)
                    db.TransactionManager.QueueForGraphicsFlush()
                    Dim hatch As Hatch = New Hatch()
                    hatch.HatchStyle = HatchStyle.Normal
                    hatch.PatternScale = 60.0 '<--change hatch scale to suit
                    hatch.PatternAngle = 0.0
                    hatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI37") '<--change pattern name to suit
                    hatch.AppendLoop(HatchLoopTypes.Outermost, ids)
                    hatch.Associative = False
                    hatch.EvaluateHatch(False)
                    btr.SetObjectIdsInFlux()
                    btr.AppendEntity(hatch)
                    tr.AddNewlyCreatedDBObject(hatch, True)
                    pl.Erase()
                    pl.Dispose()
                    ed.Regen()
                    tr.Commit()
                End Using
            End Using
        End Sub
     You then go expand this code to your needs
    Active Contributor
    02-28-2013 12:32 PM in reply to: Hallex
    This is very good... Thanks so much, Hallex, much appreciated.
    Hallex
    02-28-2013 12:59 PM in reply to: mindofcat
    Glad to help
    Happy vbneting,
    Cheers :smileyhappy:
