.NET
How to add Paletteset for AutoCAD 2013 c#
4 REPLIES 4
2097 Views, 4 Replies
I cant find Autodesk.AutoCAD.Windows.PaletteSet as My Program,
im import AutoCAD 2013 x64 Directorys
accoremgd.dll
acdbmgd.dll
as my source.
Program is using c# 4.0
Please help me.
   // this is my class source.
   using ACAD = Autodesk.AutoCAD.ApplicationServices.Core;
   using Autodesk.AutoCAD.Runtime;
4 REPLIES 4
alberto_manero_geograma
Did you add the "AcMgd" reference?
Luis Alberto Manero, Geograma.com
Thank youSmiley Wink
mchan01
Is it possible to add a usercontrol on the paletteset on runtime?
My scenario is i already have a blank palette and i would to place a button inside and as soon as i click the button, i want to add an instance of my usercontrol..
the button will act like a menu button or some add button.
norman.yuan
in reply to: mchan01
Firstly, your question is not much relevant to the original post, which has already accepted a solution. Appending your irrelevant question in this thread may result in lower attention and fewer replies. You'd better post in a new thread, and add link to other posts if you think they coul be somehow related.
To your question:
Palette itself is a UserControl (if you add a custom System.Windows.Forms.UserControl into PaletteSet), and yes, you can add Windows.Forms.Control (including UserControl) dynamically at runtime into another Control, if it is a Control container, such as UserControl, Form...
The code would be like:
public class MyPalette:UserControl
    private void Button1_Click(....)
        //Add a textbox
        TextBox txt=new TextBox()
        txt.Name="TextBox1";
        txt.Text="This is new text box";
        txt.Location=new Point(5,5);
        txt.Size=new Size(20,100);
        this.Controls.Add(txt)
        //Add something else
Although you can add controls to a control container at runtime, it does not mean it always worth doing it: it is difficult to maintain the code, debuging is a pain.
One alternative way is to add all controls at design time and turn their visibility on/off, or enable/disable them accordingly.
Norman Yuan
Drive CAD With Code
”Boost
