.NET
How to add Event Handler
2 REPLIES 2
530 Views, 2 Replies
Anyone knows how to add event handler to objects everytime the mouse select an autocad entity like polyline when this object is resize, drag or move.
Or what event is triggered when this is done.
I am not sure if I'm suppose to use overrule, but if I use overrule, how do I implement it.
here is my snippet:
Dim psr AsPromptSelectionResult= ed.SelectImplied
IfNot psr.Status = PromptStatus.OK ThenExit SubEndIfForEach objId AsObjectIdInpsr.Value.GetObjectIds()
     ValidateObject(objId)
Next
Thnaks and regards
2 REPLIES 2
how about using : Application.DocumentManager.DocumentLockModeChanged Event? hope this may help you
Thanks but I already resolved it. I use the Modified event on the object.
”Boost
