• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    How to Force GC to clear memory after à BindXRef
    177 Views, 6 Replies
    01-14-2013 04:16 AM
    Hi all, i have a issu when i use BindXRef.
    I have 4 XREF in my dwg.  so i use à Do / While for each XREF i have found.
    It work fine but whrn the Xref is big File, i have the issue "Out Of memory".
    So the question : How i can Force the GC to clear all memory not used.
    My Think is to force the GC to Clear the memory before to use BindXRef() with only one XRef before to BindXRef with another.
    Sorry for my english.
    Here my code  :
    Dim LockDoc As DocumentLock = doc.LockDocument
                    Dim MemNumBoucle As Integer = -1
                    Dim CollXRef As New ObjectIdCollection
                    Do
                        CollXRef.Clear()
                        Dim xg As XrefGraph = db.GetHostDwgXrefGraph(True)
                        Dim root As GraphNode = xg.RootNode
                        Using tr As Transaction = db.TransactionManager.StartTransaction
                            For o = 0 To root.NumOut - 1 Step 1
                                Dim child As XrefGraphNode = CType(root.Out(o), XrefGraphNode)
                                If child.XrefStatus = XrefStatus.Resolved Then
                                    Dim bl As BlockTableRecord = tr.GetObject(child.BlockTableRecordId, OpenMode.ForRead)
                                    'i_ed.WriteMessage(vbCrLf & i_indent + child.Database.Filename)
                                    ' Name of the Xref (found name)
                                    ' You can find the original path too:
                                    If bl.IsFromExternalReference = True Then
                                        GestionAUTOCAD.EcrireSurLigneDeCommande(vbCrLf & "Xref path name: " + bl.PathName)
                                        CollXRef.Add(bl.ObjectId)
                                        'détection si le liage a été fait :
                                        If MemNumBoucle <> root.NumOut Then
                                            MemNumBoucle = root.NumOut
                                            Exit For
                                        End If
                                    End If
                                End If
                            Next
                            'trouvé un xref --> Adding
                            If CollXRef.Count > 0 Then
                                Try
                                    doc.Database.BindXrefs(CollXRef, False)
                                Catch ex As Exception
                                    okErr = True
                                    MsgBox("Erreur lors de la liaison d'un Xref" & vbCrLf & "--> Essayer de lier le premier niveau", _
                                                  vbOKOnly & vbCritical, _
                                                  "Erreur Système")
                                Finally
                                    tr.Commit()
                                End Try
                            End If
                        End Using
                        GestionAUTOCAD.EcrireSurLigneDeCommande(vbCrLf & "-> " & CollXRef.Count.ToString)
                    Loop Until (CollXRef.Count = 0) Or (okErr = True)
     PS : the var MemNumBoucle is used for detection of XRef Not binding if this XRef is used in another XREf : Here a example :
    - DWG
    -- XREF : R+1
    -- XREF : ARCHI
    -------------- XREF R+1
    In this example i cant BindXREf ('R+1') alone. I need to BindXRef('ARCHI') before
    Please use plain text.
    Valued Mentor
    Re: How to Force GC to clear memory after à BindXRef
    01-14-2013 04:44 AM in reply to: AubelecBE
    Binding XRefs doesn't require a lot of memory by the CLR.
    It's AutoCAD that's using the memory, not the CLR, so there's nothing you can do with the GC to fix that.
    The only solution would be to bind one XRef at a time, save the drawing to a temporary file, exit AutoCAD completely, restart it, open the temp file, and bind another xref.
    01-14-2013 02:34 PM in reply to: DiningPhilosopher
    but why when i bind xref manually one by one i have no problem ?
    ADN Support Specialist
    Balaji_Ram
    01-22-2013 08:24 AM in reply to: AubelecBE
    Here are few suggestions that you may try :
    1) Call the Database.DisableUndoRecording with true as its parameter before the binding and restore it again after your task is done. This can help in reducing the memory usage.
    2) Try creating another custom command for binding a single xref and then call it repeatedly for binding all the xrefs.
    I havent tried these but I hope it helps in reducing the memory usage. If you can share the non-confidential drawings to reproduce the error, I can see if there are any other ways to make it work.
    Balaji
    Developer Technical Services
    Autodesk Developer Network
    Valued Mentor
    01-23-2013 05:33 AM in reply to: AubelecBE
    If you only see the problem when you're automating the process, then it could be an issue with your code, but that's just a wild guess.
    01-24-2013 04:44 AM in reply to: DiningPhilosopher
    thank i have to try the diabled option.
    I have issue when i bind manually all the file.
    in same time but no problem when i bind manualy one by one.
    02-01-2013 04:14 AM in reply to: Balaji_Ram
    so i finaly tryed your db.DisableUndoRecording
    i crash autocad.  but manyally i cant bindxref all the 5 xref. it work only one by one.
    if created a do while for bind xref one by one. :
                    db.DisableUndoRecording(True)
                    Dim OkPasserAuSuivant As Boolean
                    Dim MemNumRoot As Integer = -1
                    Dim MemNumIndex As Integer = -1
                    Do
                        CollXRef.Clear()
                        OkPasserAuSuivant = False
                        'vérification de la limitation !
                        If root.NumOut > 6 Then
                            MsgBox("Il y a plus que 3 Xrefs à lier !" & vbCrLf & _
                                   "Ce programme ne peut en lier que 2 d'affilés car AUTOCAD risque" & vbCrLf & _
                                   "de planter à cause de l'utilisation abusive de la mémoire" & vbCrLf & _
                                   "Vous en avez actuellement : " & root.NumOut.ToString & vbCrLf & _
                                   "Veuillez lier les XRef manuellement un à un et relancer ce programme.", _
                                   MsgBoxStyle.Information, "Limitation atteinte")
                            okErr = True
                            Exit Do
                        End If
                        Dim BoucleEnCours As Integer
                        'mém Num de XRef
                        If root.NumOut = 0 Then Exit Do
                        If MemNumRoot <> root.NumOut Then
                            BoucleEnCours = 0
                            MemNumIndex = BoucleEnCours
                            MemNumRoot = root.NumOut
                        Else
                            BoucleEnCours = MemNumIndex + 1
                            MemNumIndex = MemNumIndex + 1
                            If BoucleEnCours >= root.NumOut Then Exit Do
                        End If
                        Dim child As XrefGraphNode = CType(root.Out(BoucleEnCours), XrefGraphNode)
                                    GestionAUTOCAD.EcrireSurLigneDeCommande(vbCrLf & "Xref en cours : " + bl.PathName & vbCrLf, True)
                                Else
                                    OkPasserAuSuivant = True
                                End If
                                tr.Commit()
                            End Using
                        End If
                        'Next
                        'trouvé un xref --> Liage
                                Try
                                    okErr = True
                                                  "Erreur Système")
                                Finally
                                    tr.Commit()
                                End Try
                            End Using
                        End If
                        'End Using
                    Loop Until ((CollXRef.Count = 0) And (OkPasserAuSuivant = False)) Or (okErr = True)
                    db.DisableUndoRecording(False)
                    LockDoc.Dispose()
                    LockDoc = Nothing
     now i try to repeatly call my DLL for bing only one xref and i have to add a timer in each bind...
