.NET
New Member
NachiBang
Message 1 of 3 (258 Views)
How to Break loop for enter key
258 Views, 2 Replies
03-09-2012 01:58 AM
I tried the following code posted in the forum, but i need to know how to break the loop when right click/ Enter Key is pressed.
Following is the code i used:
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurEd As Editor = acDoc.Editor
        Using lock As DocumentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument
            Dim ppo As PromptPointOptions = New PromptPointOptions(vbCrLf & "Select Insertion Point:")
            Dim ppr As PromptPointResult = acCurEd.GetPoint(ppo)
            Dim _startpoint, _endpoint As Point3d
            If ppr.Status = PromptStatus.OK Then
                _startpoint = ppr.Value
            End If
            AddLayer(_LayName, True)
            Dim i As Integer = 0
            While i = 0
                Dim acCurDb As Database = acDoc.Database
                Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                    Dim _newentLine As New Line
                    ppo = New PromptPointOptions(vbCrLf & "Select Next Point")
                    ppo.BasePoint = _startpoint
                    ppo.UseBasePoint = True
                    ppr = acCurEd.GetPoint(ppo)
                        _endpoint = ppr.Value
                    Else
                        i = 1
                        Continue While
                    End If
                    _newentLine.ColorIndex = _ColorIndex
                    If _LineType.ToLower = "continuous" Then
                    ElseIf _LineType.ToLower = "byblock" Then
                    Else
                        _LineType = "ByLayer"
                    End If
                    _newentLine.StartPoint = _startpoint
                    _newentLine.EndPoint = _endpoint
                    _newentLine.Linetype = _LineType
                    _newentLine.LineWeight = _LineWeight
                    _newentLine.Layer = _LayName
                    Dim acBlkTbl As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite)
                    Dim acBlkTblRec As BlockTableRecord = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                    acBlkTblRec.AppendEntity(_newentLine)
                    acTrans.AddNewlyCreatedDBObject(_newentLine, True)
                    acTrans.Commit()
                    acBlkTblRec.Dispose()
                    acBlkTbl.Dispose()
                    _startpoint = _endpoint
                    _newentLine.Dispose()
                End Using
                acCurDb.Dispose()
            End While
        End Using
Alfred.NESWADBA
Message 2 of 3 (248 Views)
Re: How to show the Scaling and Angle
03-09-2012 02:07 AM in reply to: NachiBang
check the possible values in this line
If ppr.Status = .....
- alfred -
Alfred NESWADBA
Valued Contributor
chockalingam
Message 3 of 3 (246 Views)
03-09-2012 02:10 AM in reply to: NachiBang
Use the following line which helps you to break the loop for right click/ enter key
ppo.AllowNone = True
You are not logged in.
Ask the Community
