.NET
How to Assign a Point Style or Point Label Style back to <default>
3 REPLIES 3
GTVic
536 Views, 3 Replies
This is in the Civil 3D COM interface but I thought I'd ask here:
If the description key point style is set to "<default>"
(AeccPointDescriptionKey.PointStyle Is Nothing) = True
If it is not Nothing and you want to set the style back to "<default>" then this will give an error.
AeccPointDescriptionKey.PointStyle = Nothing
Wondering what the correct procedure is for this.
Same question for PointLabelStyle
Thanks.
3 REPLIES 3
GTVic
in reply to: GTVic
This is similar to this question which was never answered:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/Set-point-group-label-style-to-quot-non...
These are two of the options I've tried:
oPntDesKey.PointStyle = VariantType.Null
oPntDesKey.PointStyle = Nothing
Jeff_M
in reply to: GTVic
I'm guessing that you are using COM due to either working with a pre-2013 version or needing an external application. For this, I have never found a solution. However, if you are working in 2013+ and it's for use inside C3D, have you considered moving to the .NET API? With that you can set the the PointStyleId=ObjectId.Null
Jeff_M, also a frequent Swamper
GTVic
in reply to: Jeff_M
For this I'm compiling for 2013+, I previously compiled for 2011+, but when I started this code I don't think there was a .NET interface for Point Description Key Sets which I see now.
No such luck for the figure prefix database as far as I can see. Writing / debugging with "As Object" is annoying so that will be a bonus.
Thanks Jeff.
Interop:
Autodesk.AECC.Interop.UiLand.IAeccDocument.PointDescriptionKeySets
.NET:
Autodesk.Civil.DatabaseServices.PointDescriptionKeySet
Autodesk.Civil.DatabaseServices.PointDescriptionKeySetCollection
”Boost
