How edit an Associatvie Array entity in 2012 Programmatically?
JanetDavidson
JanetDavidson
My plan is to edit an Associative array entity  Programmatically and I don't know where to start.
Why can't I cast a DBobject to AssocArray ?
something like this?
Dim myarray As AssocArray = TryCast(mydbobj, AssocArray)
Why TypeOf  dbobject  is BlockReference ?
Can I get some right direction Here Please? I stuck right at begining.
Thanks Janet.
chiefbraincloud
I haven't played with them yet, but if memory serves, I think Stephen Preston did a DevCast on the subject.
A quick search gave me this Through the Interface Post:
http://through-the-interface.typepad.com/through_the_interface/2011/11/creating-a-simple-associative...
Which also points to this TTIF post:
http://through-the-interface.typepad.com/through_the_interface/2011/03/new-apis-in-autocad-2012.html
The second post has links to download the DevTV session.
JanetDavidson
Hello chief,
Thanks for reply and helping me again .
I saw that and I was able to create them using that link. Now question is how could I edit them after they added to database. Because after I get DBobject  I can't even cast them to get the proper  class.
JanetDavidson
Hello Chief . I knew you never make mistake. That is why I double check the second Link which was TTIF post. and I found what I want. Thanks again. Sorry I rushed to answer at first place.
Janet.
chiefbraincloud
Oh, believe me, I make mistakes.  Glad this wasn't one of those times. 😉
jeff
Here is one approach but might be a better way of doing it
http://www.theswamp.org/index.php?topic=37921.msg464320#msg464320
but
AssocArray.GetParameters
modify parameters
Commit
You can also find your answers @ TheSwamp
