• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    JanetDavidson
    How edit an Associatvie Array entity in 2012 Programmatically?
    148 Views, 5 Replies
    03-22-2012 09:37 AM
    My plan is to edit an Associative array entity  Programmatically and I don't know where to start.
    Why can't I cast a DBobject to AssocArray ?
    something like this?
    Dim myarray As AssocArray = TryCast(mydbobj, AssocArray)
    Why TypeOf  dbobject  is BlockReference ?
    Can I get some right direction Here Please? I stuck right at begining.
    Thanks Janet.
    Please use plain text.
    chiefbraincloud
    Re: How edit an Associatvie Array entity in 2012 Programmatically?
    03-22-2012 03:17 PM in reply to: JanetDavidson
    I haven't played with them yet, but if memory serves, I think Stephen Preston did a DevCast on the subject.
    A quick search gave me this Through the Interface Post:
    http://through-the-interface.typepad.com/through_the_interface/2011/11/creating-a-simple-associative...
    Which also points to this TTIF post:
    http://through-the-interface.typepad.com/through_the_interface/2011/03/new-apis-in-autocad-2012.html
    The second post has links to download the DevTV session.
    JanetDavidson
    03-22-2012 03:39 PM in reply to: chiefbraincloud
    Hello chief,
    Thanks for reply and helping me again .
    I saw that and I was able to create them using that link. Now question is how could I edit them after they added to database. Because after I get DBobject  I can't even cast them to get the proper  class.
    JanetDavidson
    03-22-2012 04:24 PM in reply to: chiefbraincloud
    Hello Chief . I knew you never make mistake. That is why I double check the second Link which was TTIF post. and I found what I want. Thanks again. Sorry I rushed to answer at first place.
    Janet.
    chiefbraincloud
    03-22-2012 04:33 PM in reply to: JanetDavidson
    Oh, believe me, I make mistakes.  Glad this wasn't one of those times. :smileywink:
    03-22-2012 05:35 PM in reply to: chiefbraincloud
    Here is one approach but might be a better way of doing it
    http://www.theswamp.org/index.php?topic=37921.msg464320#msg464320
    but
    AssocArray.GetParameters
    modify parameters
    Commit
    You can also find your answers @ TheSwamp
