.NET
How do you retrieve the list of open drawings AutoCAD 2011
2 REPLIES 2
497 Views, 2 Replies
I was trying to retrieve a list of the currently open drawings before running a batch script in VB .Net 2008 so that the program can check the selected file listto update against whats open already to make sure that the file isnt read only.
I can seem to figure it out... any help would be great thanks.
2 REPLIES 2
tyronebk
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
holds a DocumentCollection of all the opened documents.
cincir
what tkarapita says is true. i want to add an advice for your future affords. if you are dealing with the documents  i mean not a single document , mark your command as CommandFlags.Session so that it runs in application context and dont forget the lock the document you are dealing with.
”Boost
