.NET
How do i find a block in the BlockTable
11 REPLIES 11
Message 1 of 12
836 Views, 11 Replies
Finally trying to get my hands dirty on .NET. It's not that easy really
How do i find a BlockTabelRecord from a name?
In objectArx i got the objectId using AcDbBlockTable::getAt(const ACHAR*
entryName,AcDbObjectId& recordId);
Then I created a new AcDbBlockReference using the id, added it to the
database and i was done.
In .NET I can not find any GetAt method. Do I have to iterate the enumerator
and find it by myself?
I'm to old for this new stuff. Guess i should stay with Arx and ADS 😉
/Matt
11 REPLIES 11
Message 2 of 12
I do it with the following code, but i don't know
if it is the best way:
public bool IsBlockInDrawing(string BlockName, out ObjectId BlockId)
bool BlockIsInDrawing = false;
ObjectId tmpID = new ObjectId();
BlockId = tmpID;
using (Transaction tr = db.TransactionManager.StartTransaction())
using (BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead, false))
foreach (ObjectId tmpBlockId in bt)
using (BlockTableRecord btr = (BlockTableRecord)tr.GetObject(tmpBlockId, OpenMode.ForRead, false))
if (String.Compare(btr.Name, BlockName, true) == 0)
BlockIsInDrawing =
true;
BlockId = tmpBlockId;
break;
tr.Commit();
return BlockIsInDrawing;
Roland Feletic
Ingenieurbuero A.
Pauser Ges.m.b.H.
size=2>http://www.pauser.at
hp workstation xw4200, 3GB
quadro
fx1400
AutoCAD 2007, 3DSMax 8.0 SP 2
How do i find a
recordId);
the
I'm to
/Matt
Message 3 of 12
Thanks.
But I found a much better way (after a
while):
BlockId  = bt[BlockName]
/Matt
BlockId = tmpID;
BlockIsInDrawing =
true;
break;
tr.Commit();
Roland Feletic
Ingenieurbuero A.
Pauser Ges.m.b.H.
quadro
fx1400
Finally trying to
How do i find
recordId);
to the
and find it by
myself?
and ADS 😉
/Matt
Message 4 of 12
Great, much shorter now 😉
Roland Feletic
Ingenieurbuero A. Pauser Ges.m.b.H.
href="http://www.pauser.at">http://www.pauser.at
quadro fx1400
2
Message 5 of 12
Matt wrote:
> Thanks.
> But I found a much better way (after a while):
> /Matt
Be wary that this method WILL return erased records, whether you want them
or not. It is a serious bug in the .Net api which AutoDesk SHOULD fix.
Tony Tanzillo has done a good job of explaining this.
Perry
Message 6 of 12
But this should help, shouldn't it?
if (!BlockId.IsErased)
BlockIsInDrawing =
true;
Roland Feletic
Ingenieurbuero A.
Pauser Ges.m.b.H.
quadro
fx1400
Matt wrote:
Thanks.
/Matt
this.
Perry
Message 7 of 12
> BlockIsInDrawing = true;
> Roland Feletic
I also have a section of code that asks "if(!btr.isErased)" which returns
true, then when I attempt to open the record I get an "eWasErased" exception.
I dont trust the api in this regard. The only for sure method I know of is
to iterate the whole table, using foreach.
See the posts here "when is erased really erased" and "transaction, purge and
ewaserased".
Message 8 of 12
Have a look at this newsgroup, you'll find discussions
about the indexer behavior (it returns erased records).
To get a non-erased record you must iterate the table,
if the IsErased property of the ObjectId returned by the
indexer returns true.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"Matt" wrote in message news:5182988@discussion.autodesk.com...
Thanks.
/Matt
wrote in message news:5182890@discussion.autodesk.com...
I do it with the following code, but i don't know if it is the best way:
public bool IsBlockInDrawing(string BlockName, out ObjectId BlockId){bool BlockIsInDrawing = false;ObjectId tmpID = new ObjectId();BlockId = tmpID;using (Transaction tr = db.TransactionManager.StartTransaction())using (BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead, false)){foreach (ObjectId tmpBlockId in bt){using (BlockTableRecord btr = (BlockTableRecord)tr.GetObject(tmpBlockId, OpenMode.ForRead, false)){if (String.Compare(btr.Name, BlockName, true) == 0){BlockIsInDrawing = true;BlockId = tmpBlockId;break;}}}tr.Commit();return BlockIsInDrawing;}}
Roland Feletic
quadro fx1400
"Matt" schrieb im Newsbeitrag news:5182844@discussion.autodesk.com...
/Matt
Message 9 of 12
>> which returns true, then when I attempt to open the record
Are you opening the record with the optional third
argument to GetObject() (e.g., true = open erased
object) ?
Message 10 of 12
> object) ?
Heres the relevant snippet:
// Get the block table
BlockTable blkTbl = (BlockTable)(trans.GetObject(dBase.BlockTableId, OpenMode.ForRead));
BlockTableRecord blkTblRec = (BlockTableRecord)trans.GetObject(blkTbl[BlockTableRecord.PaperSpace], OpenMode.ForRead);
foreach (ObjectId objId in blkTblRec) //iterator should skip erased objects?
// For each object in the block table record, cast it to a block reference
DBObject dBaseObj = trans.GetObject(objId, OpenMode.ForRead);
BlockReference blkRef = dBaseObj as BlockReference;
if (blkRef != null && !blkRef.IsErased)//still getting erased !!!!!!!!!!!!
No, I didnt specifically include the "false" in the getobject statement. I thought the default
was false. Anyways, from previous discussion I was left with the impression that "getobject"
was faulty and returned erased records regardless.
Message 11 of 12
If i delete all blockreferences in the drawing and then i purge the drawing
i do not get an error.
So the error just occours when i delete it in the programm, dosn't it?
Roland Feletic
quadro fx1400
Message 12 of 12
Now i changed the function a little bit. This
should work now.
    BlockId =
new ObjectId();
        try
            BlockId = bt[BlockName];
            using (BlockTableRecord btr = (BlockTableRecord)tr.GetObject(BlockId, OpenMode.ForRead, false))
                if (!btr.IsLayout && !btr.IsAnonymous)
                    BlockIsInDrawing =
true;
        catch
        tr.Commit();
Roland
Feletic
quadro
fx1400
”Boost
