.NET
Valued Contributor
kevinsir
Message 1 of 19 (394 Views)
How can I use a graphic ellipse with text together?
394 Views, 18 Replies
03-15-2013 08:24 PM
Hello, everyone
I want to create a new order. when  using the order,It will create a  ellipse and  a DTEXT .I mean the ellipse and the DTEXT are a whole. when move the ellipse the DTEXT will alse move.However, users can  edit the  DTEXT.
Someone who can give  me some solution? Thanks very much!
Hallex
Message 2 of 19 (364 Views)
Re: How can I use a graphic ellipse with text together?
03-16-2013 07:49 AM in reply to: kevinsir
Hi Kevin,
Do you want to create the block with one attribute inside the ellipse?
Hallex
Message 3 of 19 (358 Views)
03-16-2013 08:39 AM in reply to: kevinsir
Though you could be read same code in Labs,
here is quick example
    [CommandMethod("OrderBlock", CommandFlags.Modal | CommandFlags.Redraw)]
        public static void CreateOrderLabel()
            // Get the current document and database
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                try
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                    // get current text size for attribute or use hard coded one instead
                    double txtheight = db.Textsize;
                    // block name
                    string blkName = "ORDER";
                    // check if exists
                    if (bt.Has(blkName))
                        ed.WriteMessage("\nBlock \"ORDER\" already exist.");
                        return;// if exists then exit
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Point3d inspt = new Point3d(0, 0, 0);
                    BlockTableRecord newBtr = new BlockTableRecord();
                    bt.Add(newBtr);
                    // change settings for you block to your suit:
                    newBtr.Name = blkName;
                    newBtr.Origin = inspt;
                    newBtr.BlockScaling = BlockScaling.Uniform;
                    newBtr.Units = UnitsValue.Inches;
                    newBtr.Explodable = false;
                    tr.AddNewlyCreatedDBObject(newBtr, true);
                    Vector3d normal = Vector3d.ZAxis;
                    Vector3d majorAxis = 6 * txtheight * Vector3d.XAxis;// change major axis to your suit
                    double radiusRatio = 0.4;// change ratio to your suit
                    double startAng = 0.0;
                    double endAng = Math.PI * 2;
                    Ellipse ellipse = new Ellipse(inspt, normal, majorAxis, radiusRatio, startAng, endAng);
                    ellipse.Layer = "0";
                    ellipse.LinetypeId = db.ContinuousLinetype;
                    ellipse.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0);// color by block
                    ellipse.LineWeight = LineWeight.LineWeight040;// wide lineweight 0.40, change on LineWeight.ByLineWeightDefault to discard it
                    newBtr.AppendEntity(ellipse);
                    tr.AddNewlyCreatedDBObject(ellipse, true);
                    AttributeDefinition attr = new AttributeDefinition();
                    attr.Layer = "0";
                    attr.LinetypeId = db.ContinuousLinetype;
                    attr.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0);// color by block
                    attr.LineWeight = LineWeight.ByLineWeightDefault;
                    attr.Tag = "DESCRIPTION";
                    attr.Prompt = "Order description:";
                    attr.TextString = "blah";
                    attr.Preset = true;
                    //attr.TextStyle = db.Textstyle;//<--   A2009
                    attr.TextStyleId = db.Textstyle;//<--   A2010
                    attr.Height = txtheight;
                    attr.Position = inspt;
                    attr.Justify = AttachmentPoint.MiddleCenter;
                    attr.AlignmentPoint = inspt;
                    attr.LockPositionInBlock = true;
                    attr.AdjustAlignment(db);
                    newBtr.AppendEntity(attr);
                    tr.AddNewlyCreatedDBObject(attr, true);
                    tr.Commit();
                    ed.Regen();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
Valued Contributor
kevinsir
Message 4 of 19 (354 Views)
03-16-2013 08:57 AM in reply to: kevinsir
Thanks for your repy.If the attribute can show  and edit on the paper , It is maybe perfect.
I will try your code.
Hallex
Message 5 of 19 (348 Views)
03-16-2013 09:54 AM in reply to: kevinsir
Here is VB.NET code,see my poor comments inline
        <CommandMethod("OrderBlock", CommandFlags.Modal Or CommandFlags.Redraw)> _
        Public Shared Sub CreateOrderLabel()
            ' Get the current document and database
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForWrite), BlockTable)
                    ' get current text size for attribute or use hard coded one instead
                    Dim txtheight As Double = db.Textsize
                    ' block name
                    Dim blkName As String = "ORDER"
                    ' check if exists
                    If bt.Has(blkName) Then
                        ed.WriteMessage(vbLf & "Block ""ORDER"" already exist.")
                        ' if exists then exit
                        Return
                    End If
                    Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                    Dim inspt As New Point3d(0, 0, 0)
                    Dim newBtr As New BlockTableRecord()
                    bt.Add(newBtr)
                    ' change settings for you block to your suit:
                    newBtr.Explodable = False
                    tr.AddNewlyCreatedDBObject(newBtr, True)
                    Dim normal As Vector3d = Vector3d.ZAxis
                    Dim majorAxis As Vector3d = 6 * txtheight * Vector3d.XAxis
                    ' change major axis to your suit
                    Dim radiusRatio As Double = 0.4
                    ' change ratio to your suit
                    Dim startAng As Double = 0.0
                    Dim endAng As Double = Math.PI * 2
                    Dim ellipse As New Ellipse(inspt, normal, majorAxis, radiusRatio, startAng, endAng)
                    ellipse.Layer = "0"
                    ' color by block
                    ' wide lineweight 0.40, change on LineWeight.ByLineWeightDefault to discard it
                    tr.AddNewlyCreatedDBObject(ellipse, True)
                    Dim attr As New AttributeDefinition()
                    attr.Layer = "0"
                    ' color by block
                    attr.Preset = True
                    ' using current textstyle
                    'attr.TextStyle = db.Textstyle ''<--   A2009
                    attr.TextStyleId = db.Textstyle ''<--   A2010
                    attr.LockPositionInBlock = True
                    tr.AddNewlyCreatedDBObject(attr, True)
                    tr.Commit()
                    ed.Regen()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
                End Try
            End Using
        End Sub
Valued Contributor
kevinsir
Message 6 of 19 (336 Views)
03-16-2013 08:48 PM in reply to: Hallex
Thanks a lot ! It is a nice solution. However, is there any better idea that if i want to edit description on the screen directly,never show a description dialogue.Because my customers use CAD on the pad ,maybe they want a big input UI.
Hallex
Message 7 of 19 (329 Views)
03-16-2013 11:25 PM in reply to: kevinsir
In this case discard show dialog using ATTDIA variable, see Help file
Cheers :smileyhappy:
Valued Contributor
kevinsir
Message 8 of 19 (327 Views)
03-17-2013 12:19 AM in reply to: Hallex
Can you tell me a more detailed method? Do  you mean that  when editing the attribute,  the dialogue also does not  appear ?
Valued Contributor
kevinsir
Message 9 of 19 (319 Views)
03-17-2013 04:25 AM in reply to: kevinsir
I mean can I  use this attribute like dbtext,
and another question is that is therer any setting i can set the attibute or the ellipse to be  visible or invisible!
Hallex
Message 10 of 19 (312 Views)
03-17-2013 06:03 AM in reply to: kevinsir
I have not have a time for testing and could not reach at AutoCAD now,
but you can play with attribite mode,
say specify your settings instead, e.g. in this line of code:
attr.Preset = True
You may want to play with something like
attr.Verify=true, same for Visible etc
You are not logged in.
Ask the Community
