.NET
How can I use Mline Class to draw mline in dwg using C#?
4 REPLIES 4
allentable
1177 Views, 4 Replies
hello,
I want to draw mline in the dwg automatically. Here is some codes, and what should I do next?
C# codes by VS2010,FOR AUTOCAD 2010.
 Line dashdot = new Line();
 dashdot.Linetype = "DashDot";
 MlineStyleElement off1100 = new MlineStyleElement(3720/2,Autodesk.AutoCAD.Colors.Color.FromRgb (0,0,0),dashdot .LinetypeId );
 MlineStyle mlineStyle = new MlineStyle();
  mlineStyle.Elements.Add(off1100,false );
Mline mline = new Mline();
mline.Style = mlineStyle.ObjectId;//HOW CAN I DEFINE THE MLINE? it should contain lines and I don't know
                                                      // how to add lines(may be points) into it.
The code may be wrong.
Please give me some help and advice.
Thanks in advance.
Allen
Tags (1)
4 REPLIES 4
Hallex
in reply to: allentable
Just a quick shot sorry,
without explanations
see docs for more
        [CommandMethod ("mil")]
        public void MLINECREATE()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                Mline ml = new Mline();
                ml.Style = db.CmlstyleID;
                ml.Normal = Vector3d.ZAxis;
                ml.Justification = MlineJustification.Zero;
                ml.AppendSegment(new Point3d (0,0,0));
                ml.AppendSegment(new Point3d(100, 0, 0));
                ml.AppendSegment(new Point3d(100, 80, 0));
                ml.AppendSegment(new Point3d(0, 80, 0));
                ml.IsClosed = true;
                btr.AppendEntity(ml);
                tr.AddNewlyCreatedDBObject(ml, true);
                tr.Commit();
            doc.SendStringToExecute("_ZOOM _Ob _L  ",true,false,false);
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
allentable
in reply to: Hallex
hi                   ,
Thank you for your so quick answer.
Your codes works well.
But can you give more codes about custom MlineStyle, my codes belows are wrong.
 dashdot.Linetype = "Dash";
 MlineStyleElement off1100 = new MlineStyleElement(3720 / 2, Autodesk.AutoCAD.Colors.Color.FromRgb(0, 0, 0), dashdot.LinetypeId);
 mlineStyle.Elements.Add(off1100, false);
 ml.Style = mlineStyle.ObjectId;
How can I use MlineStyle?
Allen
Hallex
Found this code somewhere on forums
no tested, see if this helps
[CommandMethod("createmlinestyle")]
public void createmlinestyle()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor editor = doc.Editor;
    Database db = doc.Database;
    using (Transaction Tx =
        DBDictionary mlineDic =
            (DBDictionary)Tx.GetObject(db.MLStyleDictionaryId,
                                              OpenMode.ForRead);
        if (!mlineDic.Contains("TEST"))
            mlineDic.UpgradeOpen();
            mlineDic.SetAt("TEST", mlineStyle);
            Tx.AddNewlyCreatedDBObject(mlineStyle, true);
            mlineStyle.EndAngle = 3.14159 * 0.5;
            mlineStyle.StartAngle = 3.14159 * 0.5;
            mlineStyle.Name = "TEST";
            Autodesk.AutoCAD.Colors.Color Color;
            Color =
                Autodesk.AutoCAD.Colors.Color.FromRgb(255, 0, 0);
            MlineStyleElement element =
                    new MlineStyleElement(0.25,
                                        Color,
                                         db.Celtype);
            mlineStyle.Elements.Add(element, true);
            element =
                    new MlineStyleElement(-0.25,
                                        Color,
                                        db.Celtype);
            mlineStyle.Elements.Add(element, false);
        Tx.Commit();
allentable
in reply to: Hallex
@Hallex,
Thanks very much.
I get what I want.
Best regards,Smiley Happy
Allen
”Boost
