.NET
.NET
Valued Contributor
kevinsir
Message 1 of 10 (203 Views)
How can I get the Blockname inserted before I select the point on the drawing?
203 Views, 9 Replies
03-21-2013 01:02 AM
Hello everyone, I have a problem. I select one block to insert . However,how can I get the Blockname before select the insered point?
I found the BlockTableRecord.BlockInsertionPoints event. It is meaning that  it can only apply to the whole BlockTableRecord type rather than some individual block references (AutoCAD INSERTs)
Is there any other event?
Moderator
Alexander.Rivilis
Message 2 of 10 (200 Views)
Re: How can I get the Blockname inserted before I select the point on the draw
03-21-2013 01:32 AM in reply to: kevinsir
kevinsir wrote:
... I select one block to insert... However,how can I get the Blockname before select the insered point?
How you select block?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
kevinsir
Message 3 of 10 (189 Views)
03-21-2013 01:50 AM in reply to: Alexander.Rivilis
Maybe there is an error. I mean inserting a new BlockReference. I select the  block on the menu !
Moderator
Alexander.Rivilis
Message 4 of 10 (179 Views)
03-21-2013 02:38 AM in reply to: kevinsir
What kind of menu? If you need help please explain this in details. Maybe with pictures...
Valued Contributor
kevinsir
Message 5 of 10 (173 Views)
03-21-2013 03:00 AM in reply to: Alexander.Rivilis
menu 'insert'--"block"  then select one block from the combobox. Click the accept button then select the insert point on the paper. the problem is that  i want to get the block name by code before select the point.
Moderator
Alexander.Rivilis
Message 6 of 10 (169 Views)
03-21-2013 03:25 AM in reply to: kevinsir
I could be wrong, but if you're trying to get the name of the block in an INSERT command before a insertion point specified, then you will not do such. It is possible only if block is from other dwg-file and in this case Database.BeginInsert event is occurring.
Think about what you want to do after and find another way.
Valued Contributor
kevinsir
Message 7 of 10 (146 Views)
03-21-2013 06:14 PM in reply to: Alexander.Rivilis
Your ideas may be a solution. However I want to do something individually by name of the blockrecord before  a new blockReference inserted!
Moderator
Alexander.Rivilis
Message 8 of 10 (138 Views)
03-21-2013 11:44 PM in reply to: kevinsir
In this case look like you have to replace command INSERT with your's own command. I do not know what "something individually by name of the blockrecord"  you want to do, but may be that can be done not before, but after inserting of block?
Valued Mentor
DiningPhilosopher
Message 9 of 10 (109 Views)
03-24-2013 05:22 PM in reply to: kevinsir
You're attempting to solve a larger problem using approaches that are myopic.
You can't for example, tell a user that they must use the INSERT dialog to insert blocks because your solution to the problem only works in that context.  IOW, there are many ways to insert a block besides the INSERT dialog, and the INSERT dialog allows the user to enter an insertion point in the dialog before they even choose the block.
IOW, it won't work.
Try describing the larger problem whcih leads you to believe that the way to solve the the problem is by handling events, because in my experience, that is usually not the best solution.
Valued Contributor
kevinsir
Message 10 of 10 (73 Views)
03-27-2013 08:59 PM in reply to: DiningPhilosopher
Thanks, DiningPhilosopher ! I will try other ways !
