.NET
How can I count the number of deactivated documents ?
6 REPLIES 6
joantopo
448 Views, 6 Replies
Hi.
I´m using the events "DocumentActivated" and  the event "DocumentDestroyed" .
With the "DocumentDestroyed" method I can know how many documents are closed and when is the last..
But, I want to know, how many documents are minimized (deactivated).
It´s to say, there aren´t any active (current) document.
Trank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
6 REPLIES 6
The DocumentCollection's Count property tells you how many documents exist.
There can be only one active document so the number of 'deactivated' documents is the value of the Count property minus 1.
When the DocumentToBeDestroyed event fires, if the document that's about to be destroyed is the only open document, then at that point, the DocumentCollection's Count property will be 1, and it means that AutoCAD is entering 'zero document state' (where there are no open documents).
ok, but if I have all my documents as a(deactivated) documents. Which is the active document?  What´s the name or Id of this?
Because I can have all my documents as a deactivated document.
Thank you for reply.
jeff
in reply to: joantopo
 How do you do that?
If you have them all "deactivated" then how could one active?
I just noticed you mention minimized so when you say "deactivated" you mean minimized?
You can still enter commands and interact with active document when all them all minimized, but I think your looking for
Application.DocumentManager.MdiActiveDocument.Window.WindowState
You can also find your answers @ TheSwamp
joantopo
in reply to: jeff
Yes, all right.
I was confusing deactivated with minimized.  I wanted to say "minimized".
I´m going to try this line code.
Thank you.
joantopo
I don´t understand because Autodesk interpret that the window state = normal is the same that state=minimized..Smiley Frustrated
                 private void callback_documentActivated(object sender, DocumentCollectionEventArgs e)
                  if (ComprobarTodosMinimizados()==false)
                     System.Windows.Forms.MessageBox.Show("abiertoooooooo");
                  else
                      System.Windows.Forms.MessageBox.Show("todos minimizados");
                 public bool ComprobarTodosMinimizados()
                     bool TodosMinimizados = false;
                     int contador = 0;
                     DocumentCollection docs = Application.DocumentManager;
                     foreach (Document doc in docs)
                        if (doc.Window.WindowState == Autodesk.AutoCAD.Windows.Window.State.Minimized);  // si se minimiza la ventana
                            contador++;
                     if (contador == Application.DocumentManager.Count)
                         TodosMinimizados = true;
                 return TodosMinimizados;
joantopo
is this right?
”Boost
