I have created a ribbon and setup the buttons to open my user manual to the correct page when F1 is pressed
but i have got a few split buttons and when i click on one of them and do F1 it just goes to the toppic for the split button and not the buttons that have been added under the split
Anyone had any eperiance with this?
Thanks in Advance
Can you clarify how you are creating the Ribbon? The help topic should be linked to the command, not to the ribbon...
I'm suspecting this is related to how you add them buttons to the Ribbon. Can you clarify how the panel stack is created?
This is a sample code, not exactly, but just in case: http://adndevblog.typepad.com/autocad/2012/09/associating-f1-help-with-ribbon-button.html
