Help! with this code to insert one block with 3 attributes...
Message 1 of 11
Hello! I need some help
I have this one file .txt with this features:
Point       North                   East                Z        Description
1          8618063,68       312415,09         75,87    T1
2          8618138,38       312428,89         70,57    B_RIO SECO
3          8618132,23       312427,75         71,90    ARENAL
4          8618126,23       312426,64         72,50    ARENAL
5          8618112,22       312424,06         73,77    ARENAL
6          8618099,78       312421,76         75,35    ARENAL
7          8618089,51       312419,86         75,84    ARENAL
8          8618132,23       312427,75         71,94    J
9          8618112,23       312424,06         73,88    J
10        8618099,82       312421,78         75,36    ARENAL
11        8618089,48       312419,87         75,85    E_1
And I generated this code for read this file and insert one block with attributes for each line of text…..
If txtPath.Text() = "" Then
            MsgBox("Select DB .txt.", MsgBoxStyle.Exclamation)
        On Error GoTo ControlErroresBD
        Dim AcadDocPt As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim AcadCurrentDBPt As Database = AcadDocPt.Database
        Dim AcadEdPt As Editor = AcadDocPt.Editor
        Dim FileBD As String = txtPath.Text()
        Dim Ext As String
        Ext = Path.GetExtension(FileBD)
        If (Not IO.File.Exists(FileBD)) Then
            MsgBox("The DB doesn’t exist", MsgBoxStyle.Critical)
            Return
        Using Reader As New IO.StreamReader(FileBD)
            While Not Reader.EndOfStream
                Dim Fila As String = Reader.ReadLine()
                Dim Valores As String() = Fila.Split(New String() {}, StringSplitOptions.RemoveEmptyEntries)
                Dim PtX, PtY, PtZ As Double
                Dim NPt, Cota, Descripcion As String
                NPt = Valores(0)
                PtY = Valores(1)
                PtX = Valores(2)
                PtZ = Valores(3)
                Cota = Valores(3
                Descripcion = Valores(4)
                Using AcadTransPt As Transaction = AcadCurrentDBPt.TransactionManager.StartTransaction()
                    Dim BloqueName As String = txtName.Text()
                    Dim AcadBlkTblIns As BlockTable
                    AcadBlkTblIns = AcadTransPt.GetObject(AcadCurrentDBPt.BlockTableId, OpenMode.ForRead)
                    If AcadBlkTblIns.Has(BloqueName) Then
                                                Dim AcadBlockRec As BlockTableRecord = AcadTransPt.GetObject(AcadBlkTblIns(BlockTableRecord.ModelSpace),
        OpenMode.ForWrite)
                        AcadBlockRec = AcadTransPt.GetObject(AcadBlkTblIns(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                        Dim AcadBlock As BlockTableRecord
                        AcadBlock = AcadTransPt.GetObject(AcadBlkTblIns.Item(BloqueName), OpenMode.ForRead, False)
                        Dim AcadBlockRef As New BlockReference(New Point3d(PtX, PtY, PtZ), AcadBlock.ObjectId)
‘To the end of this line I can insert the block,,,,,,, but I don’t know how to write the attributes…… I tried with the next code but it doesn’t work…. Some help! My bloque has 3 attributes and every tag named with “PN”, “CD” and “CT”
                        Dim AcadObj As Entity
                        For Each acObjId As ObjectId In AcadBlockRef.AttributeCollection
                                                        AcadObj = AcadTransPt.GetObject(acObjId, OpenMode.ForWrite)
                            Dim acAttDef As AttributeDefinition = TryCast(AcadObj, AttributeDefinition)
                            Dim acAttRef As AttributeReference = New AttributeReference
                            acAttRef.SetAttributeFromBlock(acAttDef, AcadBlockRef.BlockTransform)
                            acAttDef.Tag = "PN"
                            acAttDef.TextString = NPt
                            acAttRef.TextString = acAttDef.TextString
                            acAttDef.Tag = "CD"
                            acAttDef.TextString = Descripcion
                            acAttDef.Tag = "CT"
                            acAttDef.TextString = Cota
                        Next
                        AcadBlockRec.AppendEntity(AcadBlockRef)
                        AcadTransPt.AddNewlyCreatedDBObject(AcadBlockRef, True)
                        AcadTransPt.Commit()
                End Using
            End While
        End Using
ControlErroresBD:
        MsgBox(Err.Number & vbNewLine & Err.Description, MsgBoxStyle.Critical)
    End Sub
Replies (10)
Message 2 of 11
Hallex
You've ignored my previous answer on your question,
so I would not to help more
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 11
Sorry! I had it like spam, your answer....  and it was for that reason that I post it again... sorry for my english!
Message 4 of 11
Hallex
Okay, then try this code, change block name etc:
    Public Shared Function ReadCSV(filename As String, sep As String) As List(Of String())
        Dim listData As New List(Of String())
        Dim line As String() = New String() {}
        Using parser As New Microsoft.VisualBasic.FileIO.TextFieldParser(filename)
            parser.SetDelimiters(sep)
            While Not parser.EndOfData
                line = parser.ReadFields()
                listData.Add(line)
            End While
        End Using
        Return listData
    End Function
    Private Shared Sub ApplyAttibutes(ByRef db As Database, ByRef tr As Transaction, ByVal bref As BlockReference, ByVal listTags As List(Of String), ByVal listValues As List(Of String))
        Dim btr As BlockTableRecord = DirectCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
        For Each attId As ObjectId In btr
            Dim ent As Entity = DirectCast(tr.GetObject(attId, OpenMode.ForRead), Entity)
            If TypeOf ent Is AttributeDefinition Then
                Dim attDef As AttributeDefinition = DirectCast(ent, AttributeDefinition)
                Dim attRef As New AttributeReference()
                attRef.SetAttributeFromBlock(attDef, bref.BlockTransform)
                bref.AttributeCollection.AppendAttribute(attRef)
                tr.AddNewlyCreatedDBObject(attRef, True)
                If listTags.Contains(attDef.Tag) Then
                    Dim found As Integer = listTags.BinarySearch(attDef.Tag)
                    If found >= 0 Then
                        attRef.TextString = listValues(found)
                        attRef.AdjustAlignment(db)
        Next
    End Sub
    Public Shared Sub testAttributedBlocksInsert(ByRef lst As List(Of String()))
        If lst Is Nothing Then Return
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        ' change block name to your suit
        Dim blockName As String = "MY_BLOCK" ' <--- blockname
        Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem 'get current UCS matrix
        Try
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                ' to force update drawing screen
                doc.TransactionManager.EnableGraphicsFlush(True)
                Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForWrite), BlockTable)
                ' if the block table doesn't already exists, exit
                If Not bt.Has(blockName) Then
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Block " & blockName & " does not exist.")
                    Return
                Dim PtX As Double
                Dim PtY As Double
                Dim PtZ As Double
                Dim NPt As String
                Dim Cota As String
                Dim Descripcion As String
                For i As Integer = 0 To lst.Count - 1
                    'Dim blkData() As String = New String() {}
                    'blkData = lst(i)
                    Dim blkData() As String = lst(i)
                    'For Each blkData As String() In lst
                    NPt = String.Empty
                    Cota = String.Empty
                    Descripcion = String.Empty
                    PtX = New Double
                    PtY = New Double
                    PtZ = New Double
                    NPt = blkData(0).ToString()
                    'ed.WriteMessage(vbLf + "NPT: " + vbTab + "{0}" + vbLf, NPt)
                    Double.TryParse(blkData(1), PtY)
                    Double.TryParse(blkData(2), PtX)
                    Double.TryParse(blkData(3), PtZ)
                    Cota = blkData(3).ToString()
                    Descripcion = blkData(4).ToString()
                    '  Dim lstAtt As List(Of String) = New List(Of String)(New String() {NPt, Descripcion, Cota})
                    ''      Or
                    Dim lstAtt As List(Of String) = {NPt, Descripcion, Cota}.ToList()
                    ' insert the block in the current space
                    Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                    Dim occ As ObjectContextCollection = db.ObjectContextManager.GetContextCollection("ACDB_ANNOTATIONSCALES")
                    Dim pt As Point3d = New Point3d(PtX, PtY, PtZ).TransformBy(ucs)
                    'Dim pt As Point3d = ppr.Value
                    Dim bref As New BlockReference(pt, bt(blockName))
                    bref.TransformBy(ucs)
                    bref.AddContext(occ.CurrentContext)
                    'add blockreference to current space
                    btr.AppendEntity(bref)
                    tr.AddNewlyCreatedDBObject(bref, True)
                    ' set attributes to desired values
                    ApplyAttibutes(db, tr, bref, New List(Of String)(New String() {"PN", "CD", "CT"}), lstAtt) 'check right order of attributes
                    bref.RecordGraphicsModified(True) ' to force updating a block reference
                    tr.TransactionManager.QueueForGraphicsFlush()
                Next
                doc.TransactionManager.FlushGraphics()
                tr.Commit()
            End Using
        Catch ex As Autodesk.AutoCAD.Runtime.Exception
            Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message)
        Finally
            Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Pokey")
        End Try
    End Sub
    ' event on insert button click
    Private Sub btnInsert_Click(sender As System.Object, e As System.EventArgs) Handles btnInsert.Click
        Dim FileBD As String = txtPath.Text() '"C:\Test\Blocks.txt"
            Return
        'read your text file and parse
        Dim lst As List(Of String()) = ReadCSV(FileBD, vbTab) ' tab delimited!
        If lst.Count = 0 Then Return
        'remove headers from list
        lst.RemoveAt(0)
        ' insert blocks
        testAttributedBlocksInsert(lst)
        Me.Close()
    End Sub
Message 5 of 11
Thanks for your answer..... Your code will help me a lot! This weekend I'll study its proccess... If I have some doubts I'll let you know....
Message 6 of 11
Hi Hallex! I follow your code and it's amazing because it works, but I have one problem with one attribute... because just wrote 2 attributes from 3.... I changed the order but still with the error..... and I have some questions and I hope that you'll be able to help.....
in your code you used:
Dim ucs AsMatrix3d = ed.CurrentUserCoordinateSystem
and:
Dim occ AsObjectContextCollection = db.ObjectContextManager.GetContextCollection("ACDB_ANNOTATIONSCALES")
and also:
you used too: DirectCast and list, and the last "list" could it be useful to use one array?
Again Thanks for your help.... you're a master
Message 7 of 11
I forgot ask, why you used that code?..... I would like to learn about it.... and about to read one file.... I follow the option
TextFieldParser,  but if I want one code that read diferents files..... for example ".txt, .csv, .prn, .xlsx,...." I mean file that have diferents delimeters...  would I have to create one code for everything? or there's one possiblity to do it in one code.
Thanks again for your help....
Message 8 of 11
Hallex
You can avoid put particular attribute value and use
default value insted, say this wa, change this line of code:
on this one:
If listValues(found)<> String.Empty then
else
attRef.TextString=attDef.textString
end if
Instead of DirectCast you can use CType instead
this is means the matrix of the current ucs
This expression is means to use it if your object has annotation scale:
otherwise it will be ignored in the code
Again, sorry for my poor English too 🙂
Message 9 of 11
Hi Hallex! Again with the same problem with insert Attributes I just got to insert 2 of 3
I followed your code:
If
LstTags.Contains(AttDef.Tag) Then
Dim found AsInteger = LstTags.BinarySearch(AttDef.Tag)
   If found>= 0 Then
       If ListValues(AttFound) <> String.Empty Then
                            AttRef.TextString = ListValues(found)
       Else
                            AttRef.TextString = AttDef.TextString
       EndIf
   EndIf
EndIf
And I still don't understand why it doesn't read the  first value? I mean "0"
now why found contains -4? when listTags contains 3 values I mean "PT, CD, CT"
Again Thanks for your help! and you know I'm learning with you help Smiley Happy
Message 10 of 11
Hi! I did it... this is the code....
For Each attId As ObjectId In Btr
        If TypeOf ent is AttributeDefinition Then
     Dim attDef AsAttributeDefinition = DirectCast(ent, AttributeDefinition)
          Dim attRef AsNewAttributeReference()
          attRef.SetAttributeFromBlock(attDef, BRef.BlockTransform)
          BRef.AttributeCollection.AppendAttribute(attRef)
          tr.AddNewlyCreatedDBObject(attRef,True)
                        AttRef.TextString = ListValues(Count)
                    AttRef.AdjustAlignment(AcadCurrentDB)
             Count = Count + 1
Next
Again Hallex thanks for your help! I hope to count on your help if I'll have more questions....
Message 11 of 11
Sorry! I forgot this line
Dim Count As Int16 = 0 'I've added this line
             Count = Count + 1
Next
