.NET
Help..why do i cannot use docunmentcollect to open an drawing
5 REPLIES 5
469 Views, 5 Replies
Error 1 'open' is not a member of 'Autodesk.AutoCAD.ApplicationServices.DocumentCollection'.
how can i solve this problem?
5 REPLIES 5
artc2
Open is parrt of the DocumentCollectionExtension class.
in reply to: artc2
i am using autocad 2013
i have tried ur method it also do not work
Public Class test
<CommandMethod("OpenDrawing", CommandFlags.Session)> _
Public Sub OpenDrawing()
Dim acDocMgr As DocumentCollection = Application.DocumentManager
DocumentCollectionExtension.Open(acDocMgr, "C:\Users\michael.yeung\Desktop\Acad\1F_MHS.dwg", False)
End Sub
End Class
Balaji_Ram
Can you please try the attached sample project ?
It worked ok in AutoCAD 2013. You may need to change the path to the referenced assemblies.
You may also be interested in this blog post about extension methods :
http://adndevblog.typepad.com/autocad/2012/05/extension-methods-in-autocad-2013.html
Balaji
Developer Technical Services
Autodesk Developer Network
in reply to: Balaji_Ram
it also have error....
Balaji_Ram
The sample project works ok in AutoCAD 2013 in my system.
Not sure what else could be causing this error.
Maybe you can try this :
http://adndevblog.typepad.com/infrastructure/2012/08/add-is-not-a-member-of-autodeskautocadapplicati...
Balaji
”Boost
