.NET
New Member
lorenzato25
Message 1 of 4 (324 Views)
Help to print onto PDF using DWG to PDF.pc3
324 Views, 3 Replies
08-26-2013 05:22 AM
Hello friends,
need your help to make a customization in C # to print PDF documents.
I tried to modify the sample standard API this link:
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html?url=WS1a919382...
But no success, below is my code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.PlottingServices;
using System.Collections.Specialized;
namespace Plot
    public class plotter
        [CommandMethod ("Simplot" CommandFlags.Session)]
        public void Print ()
            short bgPlot =
      (Short) Application.GetSystemVariable ("BACKGROUNDPLOT");
            / / Set the BACKGROUNDPLOT = 0 temporarily.
            Application.SetSystemVariable ("BACKGROUNDPLOT", 0);
            / / Get the current document and database, and start a transaction
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database = acCurDb acDoc.Database;
            acDoc.LockDocument ();
            using (Transaction acTrans acCurDb.TransactionManager.StartTransaction = ())
                / / Reference the Layout Manager
                LayoutManager acLayoutMgr;
                acLayoutMgr = LayoutManager.Current;
                / / Get the current layout and output its name in the Command Line window
                Layout acLayout;
                acLayout = acTrans.GetObject (acLayoutMgr.GetLayoutId (acLayoutMgr.CurrentLayout)
                                             OpenMode.ForRead) the layout;
                / / Get the PlotInfo from the layout
                PlotInfo acPlInfo PlotInfo = new ();
                acPlInfo.Layout = acLayout.ObjectId;
                / / Get a copy of the layout from the PlotSettings
                PlotSettings acPlSet = new PlotSettings (acLayout.ModelType);
                acPlSet.CopyFrom (acLayout);
                / / Update the object PlotSettings
                PlotSettingsValidator acPlSetVdr = PlotSettingsValidator.Current;
                / / Set the plot type
                acPlSetVdr.SetPlotType (acPlSet,
                                       Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
                / / Set the plot scale
                acPlSetVdr.SetUseStandardScale (acPlSet, true);
                acPlSetVdr.SetStdScaleType (acPlSet, StdScaleType.ScaleToFit);
                / / Center the plot
                acPlSetVdr.SetPlotCentered (acPlSet, true);
                / / Set the plot device to use
                / / AcPlSetVdr.SetPlotConfigurationName (acPlSet "Pdfcreator", "A3");
                acPlSetVdr.SetPlotConfigurationName (acPlSet "DWG to PDF.pc3", "ISO_A3_ (297.00_x_430.00_mm)");
                / / Set the plot info to an override since it will
                / / Not be saved back to the layout
                acPlInfo.OverrideSettings = acPlSet;
                / / Validate the plot info
                PlotInfoValidator acPlInfoVdr PlotInfoValidator = new ();
                acPlInfoVdr.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
                acPlInfoVdr.Validate (acPlInfo);
                / / Check to see if the plot is already in progress
                if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
                    using (PlotEngine acPlEng PlotFactory.CreatePublishEngine = ())
                        / / Track the progress with the plot Progress dialog
                        PlotProgressDialog acPlProgDlg = new PlotProgressDialog (false,
        1
        true);
                        using (acPlProgDlg)
                            / / Sets the status messages to display When plotting starts
                            acPlProgDlg.set_PlotMsgString (PlotMessageIndex.DialogTitle,
                                                          "Plot Progress");
                            acPlProgDlg.set_PlotMsgString (PlotMessageIndex.CancelJobButtonMessage,
                                                          "Cancel Job");
                            acPlProgDlg.set_PlotMsgString (PlotMessageIndex.CancelSheetButtonMessage,
                                                          "Cancel Sheet");
                            acPlProgDlg.set_PlotMsgString (PlotMessageIndex.SheetSetProgressCaption,
                                                          "Sheet Set Progress");
                            acPlProgDlg.set_PlotMsgString (PlotMessageIndex.SheetProgressCaption,
                                                          "Progress Sheet");
                            / / Set the plot progress range
                            acPlProgDlg.LowerPlotProgressRange = 0;
                            acPlProgDlg.UpperPlotProgressRange = 100;
                            acPlProgDlg.PlotProgressPos = 0;
                            / / Display the Progress dialog
                            acPlProgDlg.OnBeginPlot ();
                            acPlProgDlg.IsVisible = true;
                            / / Start to plot the layout
                            acPlEng.BeginPlot (acPlProgDlg, null);
                            / / Define the plot output
                            acPlEng.BeginDocument (acPlInfo,
                                                  acDoc.Name,
                                                  null
                                                  1
                                                  true,
                                                  "C: \ \ MMID");
                            / / Display information about the current plot
                            acPlProgDlg.set_PlotMsgString (PlotMessageIndex.Status,
                                                          "Plotting" + acDoc.Name + "-" +
                                                          acLayout.LayoutName);
                            / / Set the sheet progress range
                            acPlProgDlg.OnBeginSheet ();
                            acPlProgDlg.LowerSheetProgressRange = 0;
                            acPlProgDlg.UpperSheetProgressRange = 100;
                            acPlProgDlg.SheetProgressPos = 0;
                            / / Plot the first sheet / layout
                            PlotPageInfo acPlPageInfo PlotPageInfo = new ();
                            acPlEng.BeginPage (acPlPageInfo,
                                              acPlInfo,
                                              true,
                                              null);
                            acPlEng.BeginGenerateGraphics (null);
                            acPlEng.EndGenerateGraphics (null);
                            / / Finish plotting the sheet / layout
                            acPlEng.EndPage (null);
                            acPlProgDlg.SheetProgressPos = 100;
                            acPlProgDlg.OnEndSheet ();
                            / / Finish plotting the document
                            acPlEng.EndDocument (null);
                            / / Finish the plot
                            acPlProgDlg.PlotProgressPos = 100;
                            acPlProgDlg.OnEndPlot ();
                            acPlEng.EndPlot (null);
                            / / Re-set the original value of BACKGROUNDPLOT.
                                                        bgPlot);
But eInvalidInput error occurs in line with the excerpt:
I believe that is the name of the printer or media format. Also tried with PDFCreator, but it generates a plt file instead of a PDF.
From already thank you ..
*Expert Elite*
_gile
Message 2 of 4 (321 Views)
Re : Help to print onto PDF using DWG to PDF.pc3
08-26-2013 05:29 AM in reply to: lorenzato25
Maybe you can get some inspiration from this one:
http://www.acadnetwork.com/index.php?topic=315.0
Gilles Chanteau
New Member
lorenzato25
Message 3 of 4 (283 Views)
08-27-2013 05:25 PM in reply to: _gile
hello,
definitely got some inspiration =)
The code below takes an object of type Document and print the PDF of the same model.
The only thing missing is a pdf generated rotate to landscape ... if anyone knows and can share would be grateful
thank you
using System;
using System.Linq;
using System.Text;
using System.IO;
using Autodesk.AutoCAD.Publishing;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace FabricaDocumentos
public class Ploter
public void Imprimir(Document doc)
short bgPlot =
(short)Application.GetSystemVariable("BACKGROUNDPLOT");
//set the BACKGROUNDPLOT = 0 temporarily.
Application.SetSystemVariable("BACKGROUNDPLOT", 0);
// Get the current document and database, and start a transaction
Document acDoc = doc;
Database acCurDb = acDoc.Database;
acDoc.LockDocument();
using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
// Reference the Layout Manager
LayoutManager acLayoutMgr = LayoutManager.Current;
// Get the current layout and output its name in the Command Line window
Layout acLayout = acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), OpenMode.ForRead) as Layout;
// Get the PlotInfo from the layout
PlotInfo acPlInfo = new PlotInfo();
// Get a copy of the PlotSettings from the layout
PlotSettings acPlSet = new PlotSettings(acLayout.ModelType);
acPlSet.CopyFrom(acLayout);
// Update the PlotSettings object
// Set the plot type
acPlSetVdr.SetPlotType(acPlSet,
// Set the plot scale
acPlSetVdr.SetUseStandardScale(acPlSet, true);
acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.ScaleToFit);
// Center the plot
acPlSetVdr.SetPlotCentered(acPlSet, true);
//Rotation
//acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees270);
// Set the plot device to use
acPlSetVdr.SetPlotConfigurationName(acPlSet, "PDFCreator", "A3");
//acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG To PDF.pc3", "ISO_A3_(297.00_x_430.00_mm)");
// Set the plot info as an override since it will
// not be saved back to the layout
// Validate the plot info
PlotInfoValidator acPlInfoVdr = new PlotInfoValidator();
acPlInfoVdr.Validate(acPlInfo);
// Check to see if a plot is already in progress
using (PlotEngine acPlEng = PlotFactory.CreatePublishEngine())
// Track the plot progress with a Progress dialog
PlotProgressDialog acPlProgDlg = new PlotProgressDialog(false,
1,
true);
using (acPlProgDlg)
// Define the status messages to display when plotting starts
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.DialogTitle,
"Plot Progress");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage,
"Cancel Job");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage,
"Cancel Sheet");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption,
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption,
"Sheet Progress");
// Set the plot progress range
// Display the Progress dialog
acPlProgDlg.OnBeginPlot();
// Start to plot the layout
acPlEng.BeginPlot(acPlProgDlg, null);
// Define the plot output
acPlEng.BeginDocument(acPlInfo,
acDoc.Name,
null,
1,
false,
"c:\\mmidXOM");
string filename = Path.ChangeExtension("C\\mmidXOM", "pdf");
// Display information about the current plot
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.Status,
"Plotting: " + acDoc.Name + " - " +
// Set the sheet progress range
acPlProgDlg.OnBeginSheet();
// Plot the first sheet/layout
PlotPageInfo acPlPageInfo = new PlotPageInfo();
acPlEng.BeginPage(acPlPageInfo,
acPlInfo,
true,
null);
acPlEng.BeginGenerateGraphics(null);
acPlEng.EndGenerateGraphics(null);
// Finish plotting the sheet/layout
acPlEng.EndPage(null);
acPlProgDlg.OnEndSheet();
// Finish plotting the document
acPlEng.EndDocument(null);
// Finish the plot
acPlProgDlg.OnEndPlot();
acPlEng.EndPlot(null);
//re-set the original value of BACKGROUNDPLOT.
bgPlot);
Valued Mentor
fieldguy
Message 4 of 4 (271 Views)
08-28-2013 07:13 AM in reply to: lorenzato25
If you use the autodesk pdf driver that you have commented out (//acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG To PDF.pc3", "ISO_A3_(297.00_x_430.00_mm)") you can select the inversed page dimensions (430.00_x_297.00_mm).
I'll bet that PDFCreator only has 1 definition of "A3".
If your layouts are landscape already, you could try PlotRotation.Degrees000.
You are not logged in.
Announcements
Need installation help?
Ask the Community
