if do you have already write something, can you send me an example?
thanks
Gpaolo
ha scritto nel messaggio news:5459510@discussion.autodesk.com...
this isn't possible... the groups are database reactors without write codes.
if You want it,,, You must write some like this..( i've alread wrote...and
it's not so easy........)
Check in destination file with a reactor the objects inserted, look the
source file, loop inside reactor groups and rebuild in your final drawing...
