.NET
Valued Mentor
gasty1001
Message 11 of 16 (409 Views)
Re: Help needed with Triangle solution calculator in VB.NET
02-10-2012 11:42 AM in reply to: SteveHeather7776
I insist that you are confused your self because the wrong positioned a,b,c values over the triangle in your screen grab. If  you have 3,4,5, then the value 5 MUST be over the hypotenuse, and NOT over a leg side. In other words where in the picture says "a" should be "c", and so with "c", given that  yo are solving the Pythagoras  in the standar form a*a+b*b=c*c. Other way just change the order of a,b,c in the formula.
Gaston Nunez
Active Member
SteveHeather7776
Message 12 of 16 (392 Views)
02-10-2012 12:53 PM in reply to: gasty1001
There is nothing wrong with the pythagoras maths at all, it doesn't matter what you call the sides, they are just labels. It wouldn't matter if you called them side dog or side cat, it is the way in which you use them. If you look at the image I have attached you will see that it works ok for the pythagoras side of it.
Valued Mentor
jeff
Message 13 of 16 (387 Views)
02-10-2012 01:12 PM in reply to: SteveHeather7776
I would redo the code to make easier, but looking real quick think about this section of code.
 If sideb = 0 Then
            sideb = Math.Sqrt((sidea * sidea) - (sidec * sidec))
            TextBoxSideb.Text = sideb
        ElseIf sidea = 0 Then
            sidea = Math.Sqrt((sideb * sideb) + (sidec * sidec))
            TextBoxSidea.Text = sidea
        ElseIf sidec = 0 Then
            sidec = Math.Sqrt((sidea * sidea) - (sideb * sideb))
            TextBoxSidec.Text = sidec
        End If
You are assuming that 2 sides will always have a value.
The sides really do not equal 0 you are using it as placeholder, might be better to take a different approach
You can also find your answers @ TheSwamp
Active Member
SteveHeather7776
Message 14 of 16 (359 Views)
02-10-2012 07:24 PM in reply to: jeff
Thanks for your reply, I think it is very obvious that I don't know very much about VB programming, but I never proffessed too either. So I am asking for help on the solution please, in other words, what is the best way to code this calculator. As I mentioned earlier, I learn things by trial and error, and by seeing correct examples that I can then manipulate into my programmes.
Many thanks,
Steve
Active Member
SteveHeather7776
Message 15 of 16 (357 Views)
02-10-2012 08:27 PM in reply to: SteveHeather7776
Hi guys,
I have changed all the lettering around as per your instructions, and added some extra code, and it works properly.
Thanks for all your help.
Steve.
New code below, and image attached:
Imports System.String
Imports System.Math
Public Class Form1
Dim angleA As Single = 90
Dim angleB As Single
Dim angleC As Single
Dim sidea As Single
Dim sideb As Single
Dim sidec As Single
Private Sub NumericUpDown1_ValueChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles NumericUpDown1.ValueChanged
Controls.Add(NumericUpDown1)
End Sub
Public Function isItNullString(ByVal value) As Boolean
If value = "" Then
Return True
Else
Return False
End If
End Function
Public Sub pythagoreanTheoremThings()
If sidec <> 0 And sidea <> 0 And sideb = 0 Then
sideb = Math.Sqrt((sidec * sidec) - (sidea * sidea))
ElseIf sideb <> 0 And sidea <> 0 And sidec = 0 Then
sidec = Math.Sqrt((sideb * sideb) + (sidea * sidea))
ElseIf sidec <> 0 And sideb <> 0 And sidea = 0 Then
sidea = Math.Sqrt((sidec * sidec) - (sideb * sideb))
End If
End Sub
Public Sub angleSums()
If angleC = 0 And angleB <> 0 Then
angleC = 180 - angleA - angleB
TextBoxAngleC.Text = angleC
End If
If angleB = 0 And angleC <> 0 Then
angleB = 180 - angleA - angleC
TextBoxAngleB.Text = angleB
End If
End Sub
Public Sub angleBasWorkingAngle()
'Angle B and side b known, find side c
If angleB <> 0 And sideb <> 0 Then
sidec = sideb / Sin(degreesToRadians(angleB))
End If
'Angle B and side a known, find side b
If angleB <> 0 And sidea <> 0 Then
sideb = sidea * Tan(degreesToRadians(angleB))
End If
'Angle B and side b known, find side a
sidea = sideb / Tan(degreesToRadians(angleB))
End If
If angleB <> 0 And sidec <> 0 Then
sidea = sidec * Cos(degreesToRadians(angleB))
End If
End Sub
Public Sub findangleC()
If angleC = 0 Then
'cos
angleC = radiansToDegrees(Acos(sideb / sidec))
End If
End Sub
Public Sub feedValues()
If Not isItNullString(TextBoxSideb.Text) Then
sideb = TextBoxSideb.Text
Else
sideb = 0
End If
If Not isItNullString(TextBoxSidea.Text) Then
sidea = TextBoxSidea.Text
Else
sidea = 0
End If
If Not isItNullString(TextBoxSidec.Text) Then
sidec = TextBoxSidec.Text
Else
sidec = 0
End If
If Not isItNullString(TextBoxAngleC.Text) Then
angleC = TextBoxAngleC.Text
Else
angleC = 0
End If
If Not isItNullString(TextBoxAngleB.Text) Then
angleB = TextBoxAngleB.Text
Else
angleB = 0
End If
End Sub
Public Function degreesToRadians(ByVal degrees As Double) As Double
Dim radians As Double
radians = (Math.PI * degrees) / 180
Return radians
End Function
Public Function radiansToDegrees(ByVal radians As Double) As Double
Dim degrees As Double
degrees = radians * (180 / Math.PI)
Return degrees
End Function
#Region " Calculate all Data "
Private Sub btnCalc_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnCalc.Click
For aaa As Integer = 0 To 2 'I just repeated this 6 times because I have a lot of processing power
'you can do it twice.
feedValues()
angleSums()
findangleC()
Next
End Sub
#End Region
#Region " Clear all input boxes "
Public Sub ClearTextBox(ByVal root As Control)
For Each ctrl As Control In root.Controls
ClearTextBox(ctrl)
If TypeOf ctrl Is TextBox Then
CType(ctrl, TextBox).Text = String.Empty
End If
Next ctrl
End Sub
#End Region
Private Sub btnClear_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnClear.Click
ClearTextBox(Me)
End Sub
Private Sub btnExit_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnExit.Click
Me.Close()
End Sub
New Member
grez_cute29
Message 16 of 16 (271 Views)
Re: Help needed with Triangle solver
10-15-2012 02:24 AM in reply to: SteveHeather7776
..how to make triangle solver?where can i create like that one?i really need it because it is our project in trigonometry.thanks for the immediate respond=)
You are not logged in.
Ask the Community
