I'm creating a program which takes an Excel spreadsheet and creates new drawings then throws blocks in those drawings and saves them. I have got it to where it reads the Excel sheet and will create a new drawing for each line in the spreadsheet. The problem is it doesn't save them and I must switch back to the first drawing before the program continues. I don't even care if the drawing gets opened Can someone help me?
<CommandMethod("CreateShopDrawing")> _ Public Sub CreateShopDrawing() ' This method can have any name beamlist() Dim i As Integer = 7 'For i As Integer = 7 To nmcount file = mybmlist.Cells(i, 2).value() filename = filepath & mybmlist.Cells(i, 2).value() & ".dwg" sheetnum = mybmlist.Cells(i, 1).value() 'MsgBox(filename) NewDrawing() BlockInsert("left") BlockInsert("right") 'tab1BlockInsert() 'tab2BlockInsert() 'sectionblockinsert() 'plan() SaveActiveDrawing(filename) 'Next i closeExcel() End Sub Private Sub beamlist() ' ********************************************************************** ' * Purpose: Beamlist Sub to open Excel and assign sheet names * ' * to objects * ' * Date: 2/11/11 * ' ********************************************************************** Dim Main_Options As New Main_Options DialogBox: Select Case ApplicationServices.Application.ShowModalDialog(Main_Options) Case System.Windows.Forms.DialogResult.Cancel GoTo EOS Case System.Windows.Forms.DialogResult.OK If Main_Options.TextBox1.Text = "" Or Main_Options.TextBox2.Text = "" Or Main_Options.TextBox3.Text = "" Then MsgBox("You must select files and folders for all the fields") GoTo DialogBox Else filepath = Main_Options.TextBox3.Text & "\" On Error GoTo ExcelError myExcel = New Microsoft.Office.Interop.Excel.Application myWorkbook = myExcel.Workbooks.Open(Main_Options.TextBox1.Text) 'MsgBox("Workbook Open") mybmlist = myExcel.Worksheets("Beam Table") mysheet = myExcel.Worksheets("ShopDwgsTables") mysched = myExcel.Worksheets("Schedules") 'MsgBox("Worksheets Open") Do While mybmlist.Cells(nmcount, 2).value <> "" nmcount = nmcount + 1 Loop 'MsgBox("number of files: " & nmcount - 7) nmcount = nmcount - 1 GoTo EOS End If End Select ExcelError: MsgBox("You need to select an Excel File that has a Beam Table, ShopDwgsTables, and Schedules tab") GoTo DialogBox EOS: End Sub Public Sub NewDrawing() '' Specify the template to use, if the template is not found '' the default settings are used. Dim strTemplatePath As String = "acad.dwt" Dim acDocMgr As DocumentCollection = ApplicationServices.Application.DocumentManager Dim acDoc As Document = acDocMgr.Add(strTemplatePath) acDocMgr.MdiActiveDocument = acDoc End Sub Public Sub SaveActiveDrawing(ByVal filepath As String) Dim acDoc As Document = ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim strDWGName As String = acDoc.Name Dim obj As Object = ApplicationServices.Application.GetSystemVariable("DWGTITLED") '' Check to see if the drawing has been named If System.Convert.ToInt16(obj) = 0 Then '' If the drawing is using a default name (Drawing1, Drawing2, etc) '' then provide a new name strDWGName = filepath End If '' Save the active drawing acDoc.Database.SaveAs(strDWGName, True, DwgVersion.Current, _ acDoc.Database.SecurityParameters) End Sub
This will create a new drawing without having to use the editor.
Public Sub NewDrawing(ByVal dwgFullPath As String)
Using db As New Database(True, False)
Using tr As Transaction = db.TransactionManager.StartTransaction()
' Lock the drawing in the editor.
Dim myDWG As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Using lock As DocumentLock = myDWG.LockDocument
' Write out new Drawing File.
db.SaveAs(dwgFullPath, DwgVersion.Current, DwgVersion.Current, db.SecurityParameters)
End Using
End Using
End Using
End Sub
