Message 1 of 1
Help: SubForm close when exist from Sub-Sub-Form
I'm working on adding a sub-sub-form to a application I built a couple years ago. It should be simple, I have Main Form A, click a button, a sub form B pop up. Now I add a button(e.g. Pop) in form B, click it, sub - sub - form C pop up. so far so good. now when I click the exit in form C, form C close fine, but form B close as well.
here is the code I show and close form c(frmO)
this is code in button Pop of form B
Forms.frmOrg frmO = new Forms.frmOrg();
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(null, frmO, true);
this is code in Exit button in form C
private void cmdExit_Click(object sender, System.EventArgs e)
this.Hide();
this.Close();
this is code in Exit in Form B
// button Exit
_dtSearchReturn.Clear();
this.Hide();
frmO.Dispose();
What kind of problem it could be? Thank you very much for you time.
Wes
AutoCAD 2006, .Net 1.1 Windows 2003 Server
this.Hide();
this.Close();
// button Exit
this.Hide();
frmO.Dispose();
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
