• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    Help Help Connecting VB.net to AutoCAD 2012. It's allmost impossable
    610 Views, 25 Replies
    04-29-2012 01:17 PM
    I have been trying to connect to AutoCAD 2012 64 bit without any luck. for some time.
    I have tryed Jerry Winters templates for autoCAD 2010 64 bit. No luck because it can't
    find the working directory.  If I try to correct that problem I come up with other errors.
    I have trying installing AutoCAD 2012 wizzard and I have no luck to get it working When I install
    It says "Visual Studio Express 2008 or 2010 not installed "when I have VS 2008 allready installed on
    my machine. Unblocking the file does not change anything.  Is a another dead end.
    I have VS 2008 express install on my AutoCAD 2012 machine 64 bit. Can some give
    a suggestion to make a VB.net connection to AutoCAD. Maybe a working sample program
    works on AutoCAD 2012 (64 bit) would help. Maybe a 2012 template for AutoCAD 2012 (64bit)
    to see if a can get some kind of AutoCAD connection.
    Any suggestions, I am about to give up on this VB.net thing.
    Thank you,
    Please use plain text.
    *Expert Elite*
    Re: Help Help Connecting VB.net to AutoCAD 2012. It's allmost impossable
    04-29-2012 01:42 PM in reply to: muckmailer
    >> Maybe a working sample programworks on AutoCAD 2012 (64 bit) would help
    At least you have samples within the ObjectARX-kit, there are samples for C++ and also for C# and VB.NET, look and download it from >>>here<<< ... it's free, but you have to register for it.
    The only things you may have to change in these samples is the folder of the files referenced.
    As AutoCAD 2012-libraries are based on Framework 4 you should follow the recomendations and you VisualStudio 2010 instead. Of course there are workarounds to get your code running and to be able to debug with Framework 3.5, but it's not designed for that.
    Good luck, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    04-30-2012 05:59 PM in reply to: muckmailer
    Ok I downloaded the AutoCAD object ARX in the above link and installed it. I find a lot of *.dg files.
    under the samples folder. Where are the VB.net sample files. When I create a new vb.net project
    I usually use *.vbproj to start a project?  Please walk me through this?
    Also, If I install VS 2010 express. Is there an expiration date on it.  I think there is not a expiration date
    on VS2008?
    Thank you,
    04-30-2012 06:27 PM in reply to: muckmailer
    Ok so they are _dg folders but it looks like there are *.vbcprog files in them I guess those are
    Net c files. Where are the vb.net project files?
    Thank you,
    *Expert Elite*
    04-30-2012 08:16 PM in reply to: muckmailer
    search for *.VBPROJ ... that brings you to all subfolder from samples\dotNet
    - alfred -
    Alfred NESWADBA
    05-01-2012 08:53 AM in reply to: muckmailer
    I went into Dot Net folder and opened Helloworld project in VS 2008 and all I got was build errors.
    I tryed Selectionset.vpproj with the same results. These programs form AutoDesk are not working.
    So what is the next step?
    Thank you,
    *Expert Elite*
    05-01-2012 08:57 AM in reply to: muckmailer
    As the readme's tell you, have you updated the references?
    - alfred -
    Alfred NESWADBA
    05-01-2012 11:48 AM in reply to: muckmailer
    Which readme file?
    I looked in the Helloworld readme file in dot net folderl
    It did not mention anything about referance files. It only talked about netloading.
    So is there another readme file I should look at?
    Thank you,
    05-01-2012 12:05 PM in reply to: muckmailer
    Here is a print screen of the Hello World program referances.
    see file attachment.
    Thank you,
    *Expert Elite*
    05-01-2012 12:52 PM in reply to: muckmailer
    what I see is that you are running VS in normal mode (it has not started AutoCAD for debugging purposes) and in parallel you have startet AutoCAD. So if now you have your DLL loaded into this AutoCAD-instance you would not be able to compile as the DLL is currently locked/is in-use by AutoCAD.
    I also see that your VS-project shows 1 error and 1 warning (lower left corner of your VS-AppWindow). As long as you have errors the usage of this project is useless.
    I think parallel to every single sample is a readme, start Windows-Explorer and go to the samples\dotNET\HelloWorld- directory:
    If you have a problem getting VS-Express into AutoCAD-debugging-mode than look to >>>this blog<<<.
    - alfred -
    Alfred NESWADBA
