Thank you for your reply.
I focused on using your CommandLine.vb. The following code is used to send the command:
CommandLine.Command("_MassElementConvert", gpid, "Y ", "D ", Omschrijving.ToString)
gpid contains the ObjectID from a Autocad.Group
But when executed, the code returns the following from autocad:
_MassElementConvert
Select objects to convert: <Bad Entity name: FFFFFFFFFFB702A0>
Y D Riolering
Any suggestions as to what i am doing wrong?
TIA, Wouter
Hello Tony,
It has been a while since my last reaction.
Thank you again for your code concerning commandposting.
But i still can't cancel a command using your routine. When i call CommandLine.Command() without args the execution crashes stating 'eInvalidResBuf'
I tried to fix this, but allas, i am not sure what to change. could you help out?
TIA and regards,
Wouter
