.NET
Having problems with sendcommand
15 REPLIES 15
Message 1 of 16
2370 Views, 15 Replies
I'm using sendcommand instead of SendStringToExecute because I need to execute right away, but the problem is that it doesn't seem to be doing that.
{code}
app.ActiveDocument.SendCommand("(setq e (handent " & Chr(34) & Poly.Handle & Chr(34) & ")) \n")
app.ActiveDocument.SendCommand("fillet p !e \n")
plypts = Poly.Coordinates
{code}
After I run the fillet command, the coordinates in Poly should be updated, or at least they were in VBA, but their not. They don't change at all. Can anyone help me with this?
Thanks Edited by: iwtblj on Dec 15, 2009 11:09 PM
15 REPLIES 15
Message 2 of 16
This is the typical VBA-style hacking that most have switched to .NET
precisely for the reason of not having to resort to that nonsense. I realize
that there a certain blogger seems to think this sort of kludgery is
acceptable, but it's really not because it basically solves one problem, and
creates many more in the process.
Where are you running this code from? A registered command? A modeless
dialog or control on a PaletteSet?
How to solve the problem depends on the answer.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6305404@discussion.autodesk.com...
that.
{code}
Chr(34) & ")) \n")
{code}
Message 3 of 16
It's from a registered command
Message 4 of 16
The code here should help:
http://www.caddzone.com/CommandLine.vb
Use it like the AutoLISP (command) function, rather than
like VBA's 'SendCommand', and you do not have to pass
LISP expressions to convert handles to entity names, you
can just pass an ObjectId where the LISP (command)
equivalent takes an entity name.
Where 'id' is the ObjectId of the polyline you want to fillet,
it would work like this:
CommandLine.Command( "._FILLET", "_P", id )
wrote in message news:6305635@discussion.autodesk.com...
Message 5 of 16
I've tried
CommandLine.Command("._FILLET", "_P", poly.ObjectID)
as well as
CommandLine.Command("._FILLET", "_P", poly.ObjectID.tostring)
but when I run this, *Invalid selection*
Message 6 of 16
This works for me, with either light or heavy polylines:
{code}
public static class Test
[CommandMethod( "FILLETPOLY" )]
public static void FilletPolyCommand()
PromptEntityOptions peo =
new PromptEntityOptions( "\nSelect a polyline: " );
peo.SetRejectMessage( "\nInvalid input, requires a polyline," );
peo.AddAllowedClass( typeof( Polyline ), false );
peo.AddAllowedClass( typeof( Polyline2d ), false );
Document doc = Application.DocumentManager.MdiActiveDocument;
PromptEntityResult per = doc.Editor.GetEntity( peo );
if( per.Status == PromptStatus.OK )
CommandLine.Command( "._FILLET", "_P", per.ObjectId );
{code}
wrote in message news:6307830@discussion.autodesk.com...
I've tried
as well as
Message 7 of 16
Ah, I see. I was using the COM objectId instead of the .NET one. It works now. Thanks.
Message 8 of 16
Looking at your OP again, I suspect you're using ActiveX rather than the
managed API.
If so, you can do it thusly:
Dim pline As AcadLWPolyline pline = ....
Dim id As ObjectId = DBObject.FromAcadObject( pline );
I've tried
as well as
Message 9 of 16
Hi Tony,
First of, i am not a professional programmer, but an enthousiast. So excuse me if i am asking something stupid.
I would like to use your CommandLine.vb with my app.
I would like to convert a large number of 3Dsolid's to individual MassElement's (an Autocad Architecture object).
There is a command available called MassElementConvert
next you have to select the object to convert (i'd like to use your code to parse the objectID)
then it askes you if you want to erase the source object's
then i want to add a description
enter the description
Is this possible to do with your code? I am also creating a registered command.
When i load your CommandLine.vb into VB.NET 2008 Express i get an error stating that 'Type 'Dictionary' is not defined'. Do i need and extra import (Autodesk runtime perhaps) or is this solved otherwise?
Thanx in advance and best regards,
Wouter
Message 10 of 16
I was able to compile CommandLine.vb as is, but perhaps there is something else
in the VB test project that's missing from your project.
Try changing this line at the top of the file:
Imports System.Collections
To this:
Imports System.Collections.Generic
wrote in message news:6312997@discussion.autodesk.com...
Hi Tony,
parse the objectID)
Wouter
Message 11 of 16
It works now, thank you!
Maybe you can help me with this:
My code copies object on certain layer's to a new drawing. So far so good.
But i want my code to begin execution on the base-drawing, and as soon as the object's are copied to the new drawing i want the code to continue executing on the new drawing. I tried to set the new drawing as 'active document', but when i execute the code get's executed on the base-drawing instead of the new one.
TIA
Wouter
Message 12 of 16
You have a problem in that case.
When your code runs in the document context (e.g., a CommandMethod), you cannot
switch documents without your code being suspended until the document it was
started in becomes active again.
You can run your code in the application context, but unfortunately from that
context you cannot use the Command() method.
The only possible solution would be to eliminate the use of the Command() method
and do it the hard way (via the API), and then execute your code in the
application context, by adding the 'CommandFlags.Session' flag to the
CommandMethod attribute for the command.
wrote in message news:6313761@discussion.autodesk.com...
TIA
Wouter
Message 13 of 16
Thank you for your reply.
I focused on using your CommandLine.vb. The following code is used to send the command:
CommandLine.Command("_MassElementConvert", gpid, "Y ", "D ", Omschrijving.ToString)
gpid contains the ObjectID from a Autocad.Group
But when executed, the code returns the following from autocad:
_MassElementConvert
Select objects to convert: <Bad Entity name: FFFFFFFFFFB702A0>
Y D Riolering
Any suggestions as to what i am doing wrong?
TIA, Wouter
Message 14 of 16
Tony,
Is it possible to send an 'cancel' (like an ESC key-stroke) command using your CommandLine.vb?
Thanx
Message 15 of 16
You can't pass groups to Command(), you have to pass an array
of the objectids and an empty string after that:
Dim entityIds As ObjectId() = Nothing
Database db = HostApplicationServices.WorkingDatabase
Using trans As Transaction = db.TransactionManager.StartTransaction()
Dim grp As Group = trans.GetObject(OpenMode.ForRead, False)
entityIds = grp.GetAllEntityIds()
trans.Commit()
End Using
' All transactions should be ended before callling Command() !!!
CommandLine.Command("_MassElementConvert")
CommandLine.Cmd( entityIds )
CommandLine.Command( "", "Y ", "D ", Omschrijving.ToString )
Regarding cancelling commands, the version of CommandLine.vb you
have does not do that, but I just posted a revised version it does at the
same URL. With it, you can cancel a command, by calling Command()
with no arguments.
wrote in message news:6313946@discussion.autodesk.com...
command:
_MassElementConvert
Y D Riolering
TIA, Wouter
Message 16 of 16
Hello Tony,
It has been a while since my last reaction.
Thank you again for your code concerning commandposting.
But i still can't cancel a command using your routine. When i call CommandLine.Command() without args the execution crashes stating 'eInvalidResBuf'
I tried to fix this, but allas, i am not sure what to change. could you help out?
TIA and regards,
Wouter
”Boost
