I have a bit of code that I use to create hatches (many thanks to those who helped me), but the names are just coded inside (like "BRICK" or "CLAY"); I would like to list all available patterns for the curent drawing(on a form, using a combobox, etc), which is the best way to go?
Thank you very much,
e.g.
Solved by Hallex. Go to Solution.
See this article and comments below
