.NET
Member
Alexey_Terno
Message 1 of 3 (233 Views)
Accepted Solution
Hatch dialog box
233 Views, 2 Replies
10-28-2013 12:57 PM
Is it possible to show hatch dialog box using .NET?
I have found one old issue (link) but it does not work with AutoCAD 2014.
Valued Mentor
Ajilal.Vijayan
Message 2 of 3 (207 Views)
Re: Hatch dialog box
10-28-2013 11:09 PM in reply to: Alexey_Terno
Please try with this code
There is a commnet from MathewWebber in the same link where you find the code.
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Imports System.Runtime.InteropServices
Imports System
Namespace HatchDialogTest
    Public Class Commands
        Private Declare Auto Function acedHatchPalletteDialog _
        Lib "acad.exe" _
        Alias "?acedHatchPalletteDialog@@YA_NPEB_W_NAEAPEA_W@Z" _
        (ByVal currentPattern As String, _
        ByVal showcustom As Boolean, _
        ByRef newpattern As IntPtr) As Boolean
        <CommandMethod("SHD")> _
        Public Sub ShowHatchDialog()
            Dim sHatchType As String = "ANGLE"
            Dim ptr As IntPtr
            Dim bRet As Boolean = _
              acedHatchPalletteDialog(sHatchType, _
                True, ptr)
            If bRet Then
                Dim sNewHatchType As String = _
                  Marshal.PtrToStringAuto(ptr)
                If sNewHatchType.ToString.Length > 0 Then
                    Dim ed As Editor
                    ed = _
                      Application.DocumentManager.MdiActiveDocument.Editor
                    ed.WriteMessage( _
                      vbLf + "Hatch type selected: " + sNewHatchType)
        End Sub
    End Class
End Namespace
Member
Alexey_Terno
Message 3 of 3 (169 Views)
10-30-2013 01:50 PM in reply to: Ajilal.Vijayan
Yes - it's works!!!
Thanks a lot!
You are not logged in.
Announcements
Need installation help?
Ask the Community
