.NET
HandleToObject fails
1 REPLY 1
mdhutchinson
561 Views, 1 Reply
 Set Room = AcadApp.ActiveDocument.HandleToObject("22add")
This line fails with an error... everything works as it should up to this line.
"22add" is a known entity handle...
AcadApp.ActiveDocument.HandleToObject response with intellesence as it should.  The error I get is... Run-time error '48': Error in loading DLL
Dim Room As AcadEntity
AcadApp.ActiveDocument.Activate
1 REPLY 1
Hallex
in reply to: mdhutchinson
Try this code, it's working on A2010, I could not have other
version to test
        Public Sub testHandleToObject()
            Dim appver As Object = TryCast(My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\AutoCAD", "CurVer", Nothing), Object)
            If appver IsNot Nothing Then
                MsgBox("You have " + "Autocad.Application." + appver.ToString() + " installed")
            Else
                MsgBox("Out of luck, sorry, use your other code to get Application")
            Dim vernum As Integer = CInt(Math.Floor(Convert.ToDouble(appver.ToString().Substring(1), CultureInfo.InvariantCulture)))
            Dim progID As String = "Autocad.Application." & vernum.ToString()
            Dim AcadApp As AcadApplication = Nothing
            Try
                AcadApp = TryCast(Marshal.GetActiveObject(progID), AcadApplication)
            Catch
                MsgBox("Cannot create object of type """ & progID & """")
                Exit Sub
            End Try
            AcadApp.Visible = True
            MsgBox("Wait!...")
            Dim acdoc As AcadDocument = AcadApp.ActiveDocument
            Dim Room As Common.AcadEntity
            Dim oEnt As Object
            oEnt = AcadApp.ActiveDocument.HandleToObject("618")
            Room = TryCast(oEnt, Common.AcadEntity)
            If Room Is Nothing Then
                MsgBox("Object did not recognised, exit...")
                Return
            Else
                MsgBox(Room.ObjectName)
                If Room.ObjectName = "AcDbPolyline" Then
                    Dim oPoly As Common.AcadLWPolyline
                    oPoly = TryCast(Room, Common.AcadLWPolyline)
                    If oPoly IsNot Nothing Then
                        MsgBox("Area: " + oPoly.Area.ToString)
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
