Grid stops overrule from working
Hi there,
I have created a polyline overrule with custom gips and worlddraw
and we have an odd occurrence.  On 3 of our test machines it works fine.
But on my machine (the best and newest one), if I have the grid turned
on the overrule wont display.  Its invisible.  If you do a select all you can
see it but you can’t select it.
I thought maybe it was a custom grip issue but then why when the grid is
Off does it work fine?  What worries me a little is that to figure this out
was purely luck.  I can put in a call to turn the grid off but this isn’t finding the
problem.
Any clues?
Thanks in advance :D.
We just tested this on some other machines and the GRID is defiantly stopping it working when activated.
Very weird.
BUMP!
No takers,
not even the mods?
Balaji_Ram
Hello Martin,
I tried a sample code that overrules polyline and then turned GRID on/off but the overrule did work correctly in both cases. Here is a very simple drawable overrule code that I am using to draw circles at each vertex of the overruled pline. I have tried it with AutoCAD 2011 and 2013 and it worked ok. Which version are you using ?
Is it system specific ? If so, have you tried resetting the AutoCAD settings by using the "Reset Settings to Default" ?
Here is the sample code. You can draw a pline and then run the Test command to select the pline.
    public class MyDrawOverrule : DrawableOverrule
        public override bool WorldDraw(Drawable drawable, WorldDraw wd)
            Autodesk.AutoCAD.DatabaseServices.Polyline pline = drawable as Autodesk.AutoCAD.DatabaseServices.Polyline;
            if (pline != null)
                short clr = 1;
                int segCount = pline.NumberOfVertices;
                for (int cnt = 0; cnt < segCount; cnt++)
                    Point3d vertexPt = pline.GetPoint3dAt(cnt);
                    SegmentType type = pline.GetSegmentType(cnt);
                    switch (type)
                        case SegmentType.Arc:
                            CircularArc2d arc2d = pline.GetArcSegment2dAt(cnt);
                            clr = wd.SubEntityTraits.Color;
                            wd.SubEntityTraits.Color = 2;
                            wd.Geometry.Circle(vertexPt, arc2d.GetLength(arc2d.GetParameterOf(arc2d.StartPoint), arc2d.GetParameterOf(arc2d.EndPoint)) * 0.2, pline.Normal);
                            wd.SubEntityTraits.Color = clr;
                            break;
                        case SegmentType.Line:
                            LineSegment2d line2d = pline.GetLineSegment2dAt(cnt);
                            wd.Geometry.Circle(vertexPt, line2d.GetLength(line2d.GetParameterOf(line2d.StartPoint), line2d.GetParameterOf(line2d.EndPoint)) * 0.2, pline.Normal);
                            break;
                        case SegmentType.Coincident:
                            break;
                        case SegmentType.Empty:
                            break;
                        case SegmentType.Point:
                            break;
            return base.WorldDraw(drawable, wd);
    public class Commands
        static MyDrawOverrule pldo = null;
        static List<ObjectId> plineIds = new List<ObjectId>();
        [CommandMethod("Test")]
        public void TestMethod()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            PromptEntityResult per = ed.GetEntity("\nSelect a polyline");
            if (per.Status != PromptStatus.OK)
                return;
            plineIds.Add(per.ObjectId);
            if (pldo == null)
                pldo = new MyDrawOverrule();
                Overrule.AddOverrule(RXObject.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.Polyline)), pldo, true);
                pldo.SetIdFilter(plineIds.ToArray());
                Overrule.Overruling = true;
            else
            using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
                Entity reg = (Entity)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
                reg.RecordGraphicsModified(true);
                tr.TransactionManager.QueueForGraphicsFlush();
                tr.Commit();
Balaji
Developer Technical Services
Autodesk Developer Network
Thanks for the reply,
It isn't machine specific because we have just tested, and the bug seems to appear on both of our machines.  We are re-writing now and adding back in some custom grips.  We believe it may be a problem there.  I will post here when I know more.
Maritn.
Thank you for that,
we found that we didn't put in a tr.Commit(); in the worlddraw.  Now it's back in it works perfectly.
😄 😄 :D:D:D:D:D
