• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    Grid stops overrule from working
    206 Views, 5 Replies
    11-10-2012 02:55 AM
    Hi there,
    I have created a polyline overrule with custom gips and worlddraw
    and we have an odd occurrence.  On 3 of our test machines it works fine.
    But on my machine (the best and newest one), if I have the grid turned
    on the overrule wont display.  Its invisible.  If you do a select all you can
    see it but you can’t select it.
    I thought maybe it was a custom grip issue but then why when the grid is
    Off does it work fine?  What worries me a little is that to figure this out
    was purely luck.  I can put in a call to turn the grid off but this isn’t finding the
    problem.
    Any clues?
    Thanks in advance :smileyvery-happy:.
    My name is Martin.. :smileyvery-happy:
    Please use plain text.
    Re: Grid stops overrule from working
    11-12-2012 01:14 AM in reply to: quigs
    We just tested this on some other machines and the GRID is defiantly stopping it working when activated.
    Very weird.
    11-13-2012 09:55 AM in reply to: quigs
    BUMP!
    No takers,
    not even the mods?
    ADN Support Specialist
    Balaji_Ram
    11-20-2012 03:14 AM in reply to: quigs
    Hello Martin,
    I tried a sample code that overrules polyline and then turned GRID on/off but the overrule did work correctly in both cases. Here is a very simple drawable overrule code that I am using to draw circles at each vertex of the overruled pline. I have tried it with AutoCAD 2011 and 2013 and it worked ok. Which version are you using ?
    Is it system specific ? If so, have you tried resetting the AutoCAD settings by using the "Reset Settings to Default" ?
    Here is the sample code. You can draw a pline and then run the Test command to select the pline.
        public class MyDrawOverrule : DrawableOverrule
            public override bool WorldDraw(Drawable drawable, WorldDraw wd)
                Autodesk.AutoCAD.DatabaseServices.Polyline pline = drawable as Autodesk.AutoCAD.DatabaseServices.Polyline;
                if (pline != null)
                    short clr = 1;
                    int segCount = pline.NumberOfVertices;
                    for (int cnt = 0; cnt < segCount; cnt++)
                        Point3d vertexPt = pline.GetPoint3dAt(cnt);
                        SegmentType type = pline.GetSegmentType(cnt);
                        switch (type)
                            case SegmentType.Arc:
                                CircularArc2d arc2d = pline.GetArcSegment2dAt(cnt);
                                clr = wd.SubEntityTraits.Color;
                                wd.SubEntityTraits.Color = 2;
                                wd.Geometry.Circle(vertexPt, arc2d.GetLength(arc2d.GetParameterOf(arc2d.StartPoint), arc2d.GetParameterOf(arc2d.EndPoint)) * 0.2, pline.Normal);
                                wd.SubEntityTraits.Color = clr;
                                break;
                            case SegmentType.Line:
                                LineSegment2d line2d = pline.GetLineSegment2dAt(cnt);
                                wd.Geometry.Circle(vertexPt, line2d.GetLength(line2d.GetParameterOf(line2d.StartPoint), line2d.GetParameterOf(line2d.EndPoint)) * 0.2, pline.Normal);
                                break;
                            case SegmentType.Coincident:
                                break;
                            case SegmentType.Empty:
                                break;
                            case SegmentType.Point:
                                break;
                return base.WorldDraw(drawable, wd);
        public class Commands
            static MyDrawOverrule pldo = null;
            static List<ObjectId> plineIds = new List<ObjectId>();
            [CommandMethod("Test")]
            public void TestMethod()
                Document doc = Application.DocumentManager.MdiActiveDocument;
                Editor ed = doc.Editor;
                PromptEntityResult per = ed.GetEntity("\nSelect a polyline");
                if (per.Status != PromptStatus.OK)
                    return;
                plineIds.Add(per.ObjectId);
                if (pldo == null)
                    pldo = new MyDrawOverrule();
                    Overrule.AddOverrule(RXObject.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.Polyline)), pldo, true);
                    pldo.SetIdFilter(plineIds.ToArray());
                    Overrule.Overruling = true;
                else
                using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
                    Entity reg = (Entity)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
                    reg.RecordGraphicsModified(true);
                    tr.TransactionManager.QueueForGraphicsFlush();
                    tr.Commit();
    Balaji
    Developer Technical Services
    Autodesk Developer Network
    11-20-2012 07:52 AM in reply to: Balaji_Ram
    Thanks for the reply,
    It isn't machine specific because we have just tested, and the bug seems to appear on both of our machines.  We are re-writing now and adding back in some custom grips.  We believe it may be a problem there.  I will post here when I know more.
    Maritn.
    11-21-2012 03:16 AM in reply to: quigs
    Thank you for that,
    we found that we didn't put in a tr.Commit(); in the worlddraw.  Now it's back in it works perfectly.
    :smileyvery-happy: :smileyvery-happy: :smileyvery-happy::smileyvery-happy::smileyvery-happy::smileyvery-happy::smileyvery-happy:
